Nissan Forums / Infiniti Forums - NICOclub > Nissan Online Mechanic > Tutorials (Printable Version)
Post Title: Tutorials 1991-1994 240sx
Posted by: vancouverbc at 5:20 PM 5/29/2007
240sx articles organized by category
Non-240sx Nissan articles
1989-1998 240sx tutorials (91-94 unless indicated) :
Abbreviations
AIV removal(PAIR valve)
Air Regulator
Alignment
Alternator removal Needs work
Antenna Install
Automatic transmission-1991-1994-FSM
Battery terminal replacement
Battery FAQ
Belts-changing
Belt-squealing
Brakes-1991-1994-FSM
Brakes-Bleeder screw
Brakes-replace rear pads
Brakes-replace rear rotors
Brake master cylinder replacement
Brake light
Buying guide-1989-1998
Cam Alignment(1991-1998)
Cam Alignment-jim wolf 91-98
Catalytic converter
Cleaning Detailing
Clutch master cylinder
Clutch Pedal
Clutch Throwout bearing
Clutch and flywheel replacmentpictures
Clutch-replacing (no pictures)
Clutch-1991-1994-FSM
Codes: retrieving and reading(1991-1994)
Codes: retrieving & reading(1995-1998)
Codes: retieving & reading(1989-90 SOHC)
Code 34 detonation/knock sensor
Compression test methodology
Computer codes: reading
Consult- OBD 1
Control arm-front lower control arm replacement
Coolant system-general
Coolant change
Coolant-Temperature sensor
Crankshaft position sensor
Crankshaft- rear seal
Crankshaft-front and rear seals
CV boot replacement
Dash removal
Defogger-rear defroster(1989-1998)
Detonation sensor/knock sensor
Differential-aftermarket install
Differential oil change
Distributor see Timing
Distributor timing
Dist. timing trouble-shoot
Door-hinge sags Needs work
Door latch troubleshooting(Driver's door)
Door Panel removal
ECU-serial numbers
ECU- Tuning
EGR removal and cleaning
EGR pipe soldering repair
Electronic help
Emissions removal-DOHC good article
Emissions Removal-SOHC
Engine-Fuel_emission-1991-1994-FSM
Engine Removal 1991-98
Engine-Head Job
Engine Build-DOHC
Exhaust manifold removal
Factory service manual-1991-1994
Factory service manual 1989 best
Factory service manual-1989-1990
Factory service manual-1995
Factory service manual-1998
Fan Clutch
Fender brace install
Fiberglassing
Flooding
Freeze plug(expansion)
Fuel filter replacement
Fuel injector Cleaning
Fuel injector replacement
Fuel Injector Leak test
Fuel pressure regulator
Fuel Pressure specs(see fuel pressure reg. article 34/43 psi)
Fuel pump install
Fuel Pump install(s14)
Fuel Pump -s14
Fuel pump Needs work
Fuel pump kill switch
Fuse & Relay Locations
Ground kit
Ground-checking
Hatch-water leak
Hatch supports/lifts
Headlight troubleshooting
Headlight switch cleaning
Headlight motor replacement
Helicoil
Idle-stalling at stop lights
Idle adjustment
IACV AAC cleaning & electrical trouble-shooting
Ignition lock/switch
Injector-See fuel
Intake manifold-DOHC good article
Intake manifold SOHC
Intake-AEM install on 1997
knock sensor/Detonation sensor
Light bulb replacement-dash
Leak down test- FUEL
Light bulb- S14 Climate control
MAF-cleaning
Master cylinder(brake) replacement
Master cylinder brake bleeder kit
Muffler- stock rear
Oil pump inspection-SOHC only
Oil Pump-DOHC
Oil Pan Removal
Oil pressure sensor
Oxygen sensor
PCV
Paint codes l
PCV-Location
Power steering-hose replacement
Power steering-rebuild for 1995
Power steering pump-removal/replacement
Power steering system-bleeding
Relays-theory
Radiator
Rear main seal
Rear main seal no pics, but more accurate
Seat upgrade
Seafoam
Seat belt Warranty
Specifications(1991-1994)
Speed Sensor
Stalling-at stop lights
Starting -hard start when engine warm
Starting-hard start when engine cold
Starter trouble-shooting-Engine won't turn over
Steering-also see power steering
Steering wheel removal
1990 steering rack replacement
Steering-rack bushing replacement
Steering-Tie rod removal
Steering-tie rod
Steering-tie rod/rack angle
Steering- s14 rack
Stereo Faq see radio
Stripped bolt remedy
Stud replacement
Subframe
Subrame(1995-1998)
Subframe bushings
Suspension-misc
Suspension: Front Struts
Suspension: Rear shocks
Suspensiion-Sway bar end link, Tension control rod, Control arm bushings(all front)
Suspension: front lower control arm replacement
Suspension-Rear ball joint
Suspension-Ball joint replacement video
Suspension-tension control rod
Suspension: Rear sway bar end link
Temperature sensor-coolant
Thermostat
Throttle position sensor(TPS)
Throwout bearing
Tie rod removal
Timing Light guide
Timing-adjusting
Timing-Distributor
Timing Chain Rattle(1991-1998)
Timing chain rattle(SOHC)(1989-90)
Timing chain install (SOHC)
Timing chain replacement(SOHC) best
Timing Chain (DOHC) Incomplete
Tires
Tire chains
Top Dead Center
Transmission seal
Transmission oil change
Transmission
Vacuum diagrams
Vacuum Line location pics
Vacuum Pump Leak
Valve removal/seal replace
VIN-reading/decoding
Water pump replacement
Water pump(1995-1998)
Wheels
Wheel stud replacement
Wheel stud replacement2
Wheel bearing replacement-rear
Windshield wiper noise fix
Window-repairing amp(1989-1995)
Window-repairing power windows(1996-1998)
Window-stuck
Window-replace motor 1995-98
Window button repair-1995 only
Wiring diagrams
****CUSTOM INSTALLS************************************
Air intake install
Air Intake install-S14-(AEM)
Air Intake-Custom S14
Brake upgrade-240sx to 300zx
Clutch install
Fan-electric wiring
Fan-wiring
Fan-electric wiring
Fan install-electric for s14
Fiberglassing
Header Intall
Hood pin install
LSD(limited slip differential) install
multichecker
Nitrous oxide-direct port wet kit 1990 240sx
Painting-headlight housing
Sound system intall 1995 240sx
Suspension-coilover conversion
Swap-auto to 5speed s14
Turbo-1989 240sx
Turbo 1990 240sx
Note: People are just sharing their experience in these articles/tutorials. The authors are not experts. Always refer to factory service manual for safety and expert opinion.
IMPORTANT DISCLAIMER: Trusting your life to something you read on the internet is just plain stupid. Get corroboration from a more reliable source, use your common sense, don't get yourself killed, and don't come crying to us if you do
Modified by vancouverbc at 2:30 AM 6/4/2009
Modified by vancouverbc at 1:16 PM 10/19/2009
Modified by vancouverbc at 1:19 PM 10/19/2009
Modified by vancouverbc at 1:29 PM 10/19/2009
Post Title: Re: Tutorials 1991-1994 240sx (vancouverbc)
Posted by: leper421 at 9:32 PM 7/10/2007
I have the complete 93 FSM in pdf format...
Post Title: Re: Tutorials 1991-1994 240sx (leper421)
Posted by: Alsontime at 10:23 AM 7/12/2007
Any info on how to get it. Anyway you could share it. I would love to have it.
Post Title: Re: Tutorials 1991-1994 240sx (Alsontime)
Posted by: leper421 at 4:16 PM 7/12/2007
If it was small I'd upload it to one of my websites, however it is 22 megs zipped. I dont want to kill my bandwidth allotment if many people download it. If you know of somewhere else I will upload it there.
Posted by: Alsontime at 9:16 PM 7/12/2007
I will see what i can come up with. Thanks.
Post Title:
Posted by: leonelrr at 8:51 AM 8/13/2007
So did anybody get it?
Modified by leonelrr at 11:01 PM 8/13/2007
Post Title: Re: (leonelrr)
Posted by: vancouverbc at 3:38 PM 8/14/2007
FACTORY SERVICE MANUAL
you can get the full 91-94 fsm in the above link. you have to keep checking back until it cycles to availabe. its widely available on the net.
Post Title: Re: (vancouverbc)
Posted by: xyzalvarez at 4:26 PM 10/30/2007
*booked!
Post Title: 89 240sx codes question
Posted by: oregon at 4:38 PM 2/11/2008
in test mode 1 I get a steady red and green led, which means I am in open loop mode? and have a failure? anyone know what I should be checking?
Post Title:
Posted by: Perry G at 10:25 AM 3/8/2008
I have a1986.5 Kingcab Z24 5speed need to replace clutch master cylinder mine says Nabco on it what does this mean????
Post Title: Re: (Perry G)
Posted by: positron_ at 3:07 PM 3/8/2008
Nabco makes it. Nissan used Nabco cylinders on their older cars, don't know about the newer models.
Post Title:
Posted by: timsoo at 11:47 AM 3/10/2008
i'm looking for a 2004 p12 primera wiring diagram can anyone please help
Post Title:
Posted by: enie35 at 12:27 PM 7/4/2008
I have a nissan quest that misfires and turns off going uphills and runs some what ok on flat roads
Post Title: Re: (enie35)
Posted by: finallya240 at 2:55 PM 1/14/2009
Entire FSM can be found and saved to your computer from 240edge.com
Post Title: Re: (finallya240)
Posted by: vancouverbc at 7:07 PM 1/17/2009
You dont have to download fsm as they are hosted by NICO here:
http://www.nicoclub.com/FSM/240sx/
Posted by: cartoonlips7 at 2:54 PM 7/25/2009
forkin love it
