1989-1994 240sx: AIV PAIR valve removal tutorial
vancouverbc
Car: 1991 240sx
stutterr
Car: 1990 240sx
hey man
I just did a ton of work to my car. Now it shakes at idle. It pulls pretty good, just that it shakes the car a little when it idles. I have to go and look tomorrow to see if my car still has AIV. Am I able to clean the unit if its there?
I am assuming this is the root of the problem. I tried disconnecting the MAF and the car dies. I just did fuel filter, fuel pump, new wires, oil change, transmission fluid change, rear diff flush, brake fluid flush.
Any idea?
Btw. I have a 1990 240sx. I am on a permit right now. My car was sitting for a while, so I ran some Motul Fuel Cleaner and filled her with 94. I've burned through half a tank and it still is rough at idle. The idle is at 800.
vancouverbc
Car: 1991 240sx
stutterr wrote:hey man
Any idea?
cleaning aiv wont help your idle. just disconnect the hose that goes to air box.
stutterr
Car: 1990 240sx
My car already has a cone intake. The MAF is plugged in, but there is a sensor that is hanging. I think it measures the air temperature.
Any idea why its shaking at idle?
It pulls nice and hard, but it shakes a little at idle.
SirSilvia
Car: Sold both my babies
can I just take that stuff out and shove it in a box in case I need it if I ever move to a place that has emissions? Tired of dealing with the EGR crap.
mick
Car: 1990 240SX
Must the AIV be in the compartment for California smog?
jznsx
Car: 240sx s13
mick wrote:Must the AIV be in the compartment for California smog?
I doubt it since the later models didnt even come with it
Slide_Society
vancouverbc wrote:I did not have a welder or a bolt that would fit the opening :
I went to a hardware store with a spare hacked up collector (down)pipe and found out that the pipe is a 15/16" thread. I couldn't find the proper bolt so I went to the plumbing section and picked up a 15/16" short end connector and a screw cap for the other end. Going to remove the AIV and RTV the threads on the threads and plug it up in a day or two.
mick
Car: 1990 240SX
It came with the S13 models.It makes the engine run richer during warmup.The ECU expects it.
I cleaned mine out and reinstalled it.
Modified by mick at 4:41 PM 9/3/2009
mick
Car: 1990 240SX
Spray it glossy black-It looks better
Modified by mick at 4:42 PM 9/3/2009
