Back to Index of all Tutorials
Introduction- You should be able to remove alternator without removing anything else as long as you remove alternator from bottom. You will have to remove the cover that protects bottom of engine if it is still in place. I would say this removing alternator is pretty easy.
Buying alternator:
The best price is likely from a shop that specializes in rebuilding alternators and starters. listed under auto electrical in phone book. There is normally a refundable core charge. you could also try junk yard if you are short of funds. Ebay seems to have very good prices.
Procedure for removing
1. Disconnect the negative battery terminal.( VERY IMPORTANT IN THIS CASE)2. Disconnect black wire at (labeled m)alternator with 8mm wrench. Disconnect white wire with 10mm wrench(labeled battery). Unplug the main alternator plug.(squeeze to release)3. Back off the tensioner bolt a bit to give yourself some room. Use 14mm socket and access from the top.
4.Completely remove the bolt that connects tensioner to alternator. Your tensioner will now be dangling a bit.(access from under car)
5.Completely remove the pivot bolt with 14mm socket (access from under car). There is an odd shaped nut at the other end. The bolt only threads into this nut and passes through alternator and alternator bracket without any threads. You will need to use a small locking pliers on bolt and hit with rock to get bolt out. The lower fan shroud will get in the way a bit but you can do this without removing shroud.
6. I used a small rock to bang the alternator off the alternator bracket. The alternator than comes down through the bottom. You have to twist the alternator to steer it out to freedom.
7. Reinstall is reverse of uninstall. Use a screwdriver to help align the hole for pivot bolt. clean pivot bolt so it slides easier.
End of removal instructions
Description of pivot bolt and tensioner:
There is a 14mm bolt at bottom(alternator pivots on this bolt) and the two 14mm bolts associated with tensioner at top. The bottom bolt(pivot bolt) and the bolt that locks tensioner to engine , face front of car. The bolt(long bolt) used to adjust tension is accessed from passenger side of car.
You dont need to pry the alternator to tighten it. Tightening the tensioner will tighten the belt. Once you have tightened the tensioner, the alternator is fixed in place. The pivot bolt and the tensioner locking bolt can be loose and the the alternator will still be fixed in place.
IMPORTANT you have to back off the tensioner and loosen the pivot bolt and tensioner locking bolt before alternator will move to allow removal of belt. Three things to loosen before the alternator is free to move!
Belt deflection specs:
ALTERNATOR:-belt deflection with engine cold mm(inches).....max limit 11 (0.43) .....adjusting used belt 7-8 (0.28-0.31).....new belt 6-7 ( 0.24-0.28)
pivot
top of alt
Alternator bracket. One per car of course. bracket is connected to engine. You can put end of hammer handle on square nut and push the alternator back to tight position and vice versa.
from 1991 factory service manual
Note that there are two types of alternator so confirm which is for your car:hitachi Alternator
Mitusbishi alternator
Links
alternator testing
http://jgdarden.com/batteryfaq/carfaq5.htm
bolt sizes
pivot bolt- M10x1.5x100. Same bolt that secure the A/C compressor the bracket.
Modified by vancouverbc at 9:39 PM 1/2/2010
