Okay, here's the summary on speed sensors.KA24E: Same speed sensor just like KA24DE, but has 2 different pinion gears. Sport Pacakage has same pinion gear as KA24DE. KA24DE pinion gear has 20 teeth(not sure if you can go by this or size of it), so be careful if you are dealing with manual transmission from KA24E and it didn't come with speed sensor. Both transmission and speed sensor gears will get messed up if you get a wrong speed sensor and plug it in.94_240sx wrote:
KA24DE: s13 and s14 speed sensors are interchangeable. s13 has aluminum casing with long wire and plug attached and s14 speed sensor has plastic housing with no wires. SR20DET transmission speed sensors also have same part numbers as KA24DE s13 & s14, so you can use them for sure.
I compared s13(Chuki) and s14 speed sensors(from 96) carefully and they are basically the same. Gears look exactly the same and both have 20 teeth. I'll post a side by side picture tonight. I think clusters act differently based on where they getting the inputs from. Anyway, you better match the chassis and speed sensor like Hijacker said
From the 1991 factory service manual:
So yeah I hope this helps some else as much as it has helped me. I still need to get underneath and check out how to get the thing off but I heard that its just a bolt or screw that is relatively easy to get off. twist as you take off.
s14 sensor again:KFL wrote: The top one is the s13 lower is s14 basically identical. ss in red.Yes, I do have the s13 speed sensor, I can probably part with it. Email [email protected]
Modified by vancouverbc at 11:58 PM 1/4/2009
Modified by vancouverbc at 11:59 PM 1/4/2009
Modified by vancouverbc at 12:02 AM 1/5/2009
