94_240sx »
https://forums.nicoclub.com/94-240sx-u26401.html
Mon Feb 25, 2008 4:19 am
I just did this yesterday, and I thought I could share this with you guys. This will take only a couple of minutes.
This is a throwout bearing that came with a new clutch kit. My old one was loose and it was turning really well. Someone said it shouldn't turn like that, so I figured I should replace old one with a new one.
First, butt sockets together like this and tape them.
Place old bearing and sleeve on top of sockets.
Put a large socket in the middle and just tab it out. You don't have to hit it hard. I also sprayed PB Blaster a little bit.
It'll come out like this.
This is a new bearing on release sleeve.
36mm socket fits perfect. Tab it to put the bearing on the sleeve. Again, you don't have to hit it hard.
It's not going to go all the way in with a 36mm socket, so I used a roll of magnetic tape like this to push the bearing all the way in.
OEM bearing is on the right side and new bearing pressed to the release sleeve on the leaft side.
Unfortunately, I found out aftermarket bearing has some play. It moves around 1-2mm like in below picture. I removed it from the sleeve and will buy an OEM bearing. You should inspect the bearing before put it on. I hit it very lightly, so there's no way it was damaged during installation. Quality of OEM bearing looks much better than aftermarket anyway. Aftermarket bearing came with a clutch kit for free, so I guess I got what I paid for.
Modified by 94_240sx at 8:51 AM 2/25/2008
