Return to tutorial index
Adjusting
Tools
-7mm socket-7mm open end wrench-multimeter
You adjust TPS by loosening 2-7mm bolts and rotating tps until you read .44 volts on your multimeter or you can use Consult software. You take the reading with the ignition on and the connector connected. You have to back probe the connector. Inspect TPS for corrosion. The throttle is closed when you measure .44 volts.
Modified by vancouverbc at 8:16 PM 12/24/2009
Modified by vancouverbc at 8:18 PM 12/24/2009
Modified by vancouverbc at 8:19 PM 12/24/2009
