tie rod trouble
dhballa8588
Car: 90 dual cam hatch
i have recently bent a tie rod on my dd s13...so i am pulling one off my parts car and im not sure how to get it off...i think that you unscrew it from where the ball joint is...but if someone could find a pic and show me it would be really helpful
dhballa8588
anyone?...im sure someone has done this before... i would like to get it done before dark...thanks
silpena
Car: Nis1993 san 240sx super hicas(wrecked)
soon to come to s-chasis
if urs parts car and u don't care about messing up the boot for the ball joint get a pickle fork or a chizel and hammer it out the ball joint has a slit in it inside the fitting.
positron1
Car: Project: 1993 Nissan 240SX Coupe SR
Daily: 2010 Honda Civic Coupe
Are you replacing the inner tie rod/outer tie rod or both?The outer tie rod can be unscrewed around the middle where the washer is and the inner tie rod has a big nut with a locking spacer that needs to be removed.
dhballa8588
i am putting on the whole piece that you have pictured... how do you get the locking spacer off?
positron1
The new inner tie rods come with a new locking spacer. You need to pry the old lock spacer off. I used a prybar and a set of pliers. I bent the edges up with the pliers and used a prybar to bend them back the rest of the way if I remember correctly. It comes off when you get the edges from around the big nut.
dhballa8588
alright... thanks alot man... i should have my car moving again tommorrow :D
