Back to TUTORIAL Index
Ignition switchthis is what is called the ignition switch. the key rotates it to make different connections. if you put screwdriver in plastic blue part you can rotate the switch the same way key rotates it. $47 at napa. The electrical switch comes with assembly but is very distinct and separable part.
full view of ignition switch
Lock assembly/ignition switch combothe following pic shows the entire assembly. the ignition switch is held in by one small screw.$113 for switch/lock assembly at rock auto
part numbers
If you are talking about the steering wheel lock/ignition switch assembly, Nissan refers to them as SOP - Lockset Steering:Model Year:1989-1994 ALL - Part # 48700-40F861995-1998 Auto transmission - Part # 48700-72F251995-1998 Manual transmission - Part # 48700-73F25 price $134.00 (as of March 2003)Removal procedure
1.remove 6 philips head screws holding steering column on
2.unplug some of the connectors to get access to tamper proof bolts3.drill hole in bolt heads and remove bolts with extractor(pretty easy to get out)extractor is seen in the following picture
4.the switch is held on by small screw. remove.The ignition switch is on the opposite side of steering column from ignition lock.
5.put new lock assembly on. the left side bolt wont fit because the head is not sheared off. I just reused one of the old bolts. Otherwise, you have to take steering wheel and combination switch off.6.replace the plastic steering column that encompasses the combination switch and lock cylinder
Alternate explanation
Removal of the damaged steering wheel lock/ignition switch requires that you drill out the anti-tamper bolts that hold the steering wheel lock/ignition switch assembly to the steering column. Not that difficult to do, but may require the use of a bolt drill-out extractor set.
http://www.handsontools.com/st...=8242Once you remove the two anti-tamper bolts the steering wheel lock/ignition switch assembly will literally fall off the steering column. Replacement is a matter of properly positioning the new replacement unit in & hand tightening the bolts up. Make sure you test the fit PRIOR to torquing down the anti-tamper bolts. Once you snap the heads off those anti-tamper bolts, you wont' be able to remove or readjust the /steering lock/ignition switch assembly.
Lots of pictures
[/QUOTE]
Modified by vancouverbc at 3:10 PM 9/8/2009
Modified by vancouverbc at 3:12 PM 9/8/2009
