vancouverbc »
https://forums.nicoclub.com/vancouverbc-u10923.html
Wed Jan 14, 2009 10:28 pm
Back to Tutorials Index
Introduction Known by many names ie trunk lifts, trunk stays, hatch supports etc. None of the parts of the original supports are recycleable. When you buy replacement supports, you need two ball joints that screw into trunk door where the original fittings went. The replacement supports have receivers on either end to plug into new ball joints. you can get them for about $15 each at Rock Auto.
Stock lifts
12mm bolt at bottom.
8mm at top(ball joint doesnt come out)
oem replacement
metal clips for holding ball joint in
Modified by vancouverbc at 12:57 AM 1/15/2009
Modified by vancouverbc at 12:59 AM 1/15/2009
Modified by vancouverbc at 1:06 AM 1/15/2009
Modified by vancouverbc at 11:27 PM 1/16/2009
