Anyone ever replace their front main seal?
Jaino40
Car: 1993 Nissan 240sx
I am going to replace my front main seal in a little bit. Does anyone know how long that usually takes? I am not familiar with the KA. Plz help. Thnks
bruinbear714
If you have the right tools, 1 hour.
If not, a few hours.
Right tools = pulley puller, seal puller, and your basic mechanics set.
chrismo240sx
Car: 92 240sx HB
S13 Blacktop
i did mine like 2 or 3 days ago...pretty simple job.
my fan was already off so i just needed to get the crank pulley off then pull out the old seal. it took me no more than 45 mins.
the hardest part was getting the old seal out!!
putting in the new one and the rest back together is cake and takes like 5-10 mins.
Jaino40
Thanks. My buddy and i changed it last nite. Took only an hour.
ddgsxr504
Car: 1995 Nissan 240SX SE 2007 Infinit M35 Sport 2011 Nissan Pathfinder Silver Edition
Remove fan, remove fan shroud, remove belts, remove pulley bolt, remove pulley. The seal can be removed gently with a large flat head screwdriver, mine came out with ease.
Jaino40
yep thats what i did. Unfortunately the idiot at the local autozone gave me the rear main seal, so i had to go switch it. Only to find out that AUTOZONE's front seals didnt fit. went to Nissan and got the OEM one for 11 bucks. PERFECT fit.
ddgsxr504
Jaino40 wrote:yep thats what i did. Went to Nissan and got the OEM one for 11 bucks. PERFECT fit.
Congrats, pour yourself a beer and feel good that now you don't have to listen to the ol' lady yell at you about the oil spill you were previously leaving under your car on the driveway.
VspecR
Car: 1995 240sx
i'm in the middle of replacing my Seal, got the old one out and the new one in.
I used the old seal to place on top of the new one while hitting the seal in and It went too far back and setted against the back part of the hole where the seal goes in, Is thisokay? or do I have to have the seal flush with the opening of where it goes into?
MAXIMUS Nismo
Car: 95 240sx SE
I'm about to do this soon. Possibly on Tursday.
Quote »Remove fan, remove fan shroud, remove belts, remove pulley bolt, remove pulley. The seal can be removed gently with a large flat head screwdriver, mine came out with ease. [/quote]1) so I have to find out how to remove the fan, then I can take the fan shroud out. But to take the shroud out, I must take the intake off first.
2) Remove belts. how do I do this? Please be as detailed as possible.
3) Remove pulley bolt. I hear this is a hard one to do. soak bolt in WD-40, 27mm socket on a breaker bar. how do I prevent it from rotating when I try to loosen it?
4) Remove pulley. Can I rent a pulley puller form autozone?
5) remove seal with screwdriver. sounds simple enough.
Anthing I must know about? Will oil come rushing out?
When putting these things back together, what is the torque specs for the pulley bolt?
Modified by MAXIMUS Nismo at 11:57 PM 4/17/2009
vancouverbc
Car: 1991 240sx
-4 10mm nuts hold fan on. i used a large screwdriver to hold the fan still.
-look up belt in tutorial link in my signature
3) Remove pulley bolt. I hear this is a hard one to do. soak bolt in WD-40, 27mm socket on a breaker bar. how do I prevent it from rotating when I try to loosen it? i have not done this but someone said to rest the bar on the ground and crank. i guess with the engine disable somehow
probably. if it is not out. they are cheap to buy. you need one that will fit.
see timing chain replacement tutorial for picture
not sure but i think people say to grease the new seal
prolly no spec. i guess you tighten with it in gear? not sure
Modified by MAXIMUS Nismo at 11:57 PM 4/17/2009[/QUOTE]
Modified by vancouverbc at 9:49 PM 4/20/2009
vancouverbc
Car: 1991 240sx
MY SEAL CAME GREASED
ricehater7
Car: 1993 240sx
you won't be able to yank off that upper shroud without removing upper radiator hose cause its in the way. don't forget to drain coolant.
