Tie Rod Replacement
240sx_Guy
Car: Rusty '95 240sx MT
Difficulty: ** to ***
Time: x < 1 hour
Cost: 70 for OEM
Tools:
-Jackstands, Jack-Socket wrench-Wrenches, larger size -Pliers-Other basic tools based on situation
Materials:
- Inner tie rod, outer tie rod (bolts and pins come with)
Procedure:Take Wheels of designated side off and turn wheel for easy accessundo the codder pin and unbolt the castle nutTake the boot off the end of the inner tie rod (reuse later)Unhook the bracket holding the inner end of the inner tie rodunbolt the connection connect the new tie rod assembly, replace boot or reuse, connect iner and outer making sure you have the same dimensions as the previous tie rod Connect the outer tie rod to the spindlesecure with coder pinattach bootand put on the wheels...
test around the block and in your best interest; take the car for and alignments
thanks to PinkFishTacoyum for taking pics and for taking off the wheels
pinkfishtacoyum
Car: non-existent
Job well done if i do say so myself
240sx_Guy
thanks kevin
onosqv
Car: '92 240sx Vert
You're lucky, my tie rod end was basically seized into the spindle - very difficult to remove, even w/ the ball-joint popper tools.
You make it seem so easy, you bastard
240sx_Guy
oh hell it was not the easiest job
well before the new tie rod i took the old one out to bend it striate, that was a p.i.m.a.
the tool is a pickle fork btw
srpowered240sx
Car: 90 240sx-sr, 92 F-150, 00 bmw 323ci, 1991 s13 coupe, 99 F250 Dsl
good write up, easy job, but you make it look easier.
240sx_Guy
thank you sir
hope that ankle gets better
onosqv
Car: '92 240sx Vert
240sx_Guy wrote:the tool is a pickle fork btw
Only if you want to destroy the old tie rod end... I used a pickle fork & ball joint popper. The pickle fork works, but completely demolishes the old tie rod end bushing.
This isn't normally an issue, but I wanted to transfer from one car -> next one time, and pickle fork is out of the question.
Now I run spherical bearings there anyway, so no issues @ all, hee hee.
vancouverbc
Car: 1991 240sx
[QUOTE=vancouverbc]
i bought this for around $15. have not tried it.
i think op meant cotter pin and i dont think that is the correct way to install cotter pin. the castle nut , i think is 19 mm.
there is a special tool for the inner tie rod removal .
someone mentioned a crow foot wrench for taking off the tie rod end. this nut is 19 mm.
zerothread?id=371240
Modified by vancouverbc at 9:20 PM 10/6/2008
Modified by vancouverbc at 6:47 PM 10/11/2008
vancouverbc
Car: 1991 240sx
keith0486
what order do you remove them im confused lol jk
S133P3R
Car: 1989 S13 240sx
Im replacing my entire steering rack on my S13 didnt see a complete write up so ill compile my experiences into a post when i finish.... on with my question...
I see most ppl say use a ball joint remover/ crows foot/ pickle tickler (or whatever) but as far as re-connecting the tie rod ends to knuckles, do you need any special tools to push the rod end bolt up thru the knuckle arm?
vancouverbc
Car: 1991 240sx
S133P3R wrote:Im replacing my entire steering rack on my S13 didnt see a complete write up so ill compile my experiences into a post when i finish.... on with my question...
nope. just tighten the nut.
looking forward to your write up . pictures. pictures. pictures. quality.
vancouverbc
Car: 1991 240sx
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
Holy hell..... look at all the rust.
S133P3R
Car: 1989 S13 240sx
thanks for the links. ill tr to get some quality pics of either me or my friend can keep our hands clean enuff to operate a camera.also,i am using the bushing replacement post as a starting point and i dont know if i want to put the angle mod in as the rack was sold to me rebuilt and i dont want to pull it all apart yet.
MastaYu
Car: 92 Nissan 240SX SE HB
wish this write up happened before i installed mine. Nice job
twoclark426
Car: 240sx
Wow. Thanks so much for posting this. I am a complete noob at working on cars, but I bought my 92 to start learning. Had a bent inner tie rod on drivers side, did the job in 1.5 hours. Great pics and info!
sebazztard
Car: 1992 Nissan 240sx rb25det project. 2000 Honda Accord LX DD. 1992 Nissan 300zx NA.
dude you just need a hammer the side to get the outer to pop out, theres no need for any tools, ive done this dozens of times without a single problem. other than that gj.
240sx_Guy
no problem.
Protector
Car: 1998 B14 Nissan Sentra GXE
Thanks for the great write up! Do you have any tips on how to remove the tie rods with round inner ball joints? I'm trying to swap mine, but when I took the boot off, I saw that the ball joints were round, and did not have a nut on them for me to grab with a wrench or adjustable pliers (see pictures below). I'm not sure how to take the tie rod off, short of removing the entire steering gear assembly. Any ideas would be appreciated. Thanks.
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
weird... they all should look like this
Razi
Car: Moo
Perhaps try a pipe wrench?
Protector
Pipe wrench was too big to fit. I did manage to get them off with a pair of curved-jaw vice grips. Thank you for your suggestions.
