Glyph »
https://forums.nicoclub.com/glyph-u39709.html
Tue Apr 03, 2007 8:26 pm
Okay, so I decided to pull one of my subs and replace it with a new amp. To keep the symmetry of my trunk, I'm going to make a nice cover for it out of fiberglass to match the sub box on the opposite side. Since 'glassing is a skill that can often come in handy, I've decided to capture the entire project on film and document it here for all you Niconauts. On with the show.
Let's start with materialsOne container of fiberglass resin (I prefer Bondo brand but pretty much any will do)Fiberglass mattOne small can of BondoSeveral pairs of thin plastic glovesApprox 5 cheap paint brushesPam oven cleanerspray adhesiveMasking tapecontainers to mix resin inscrap pieces of particle board or fiber board3 or so sheets of rough sandpaper (or better yet a palm sized sander)3 or so sheets of 400grit wet/dry sandpaperA Dremel is real helpful maybe even necessary
That's all I can think of. Total cost provided you have the tools is around $50 or so.
Okay, so we'll start by taping up the area you want to fiberglass. It works best if you work from the bottom up as that decreases the chances of the resin seeping through the tape layers as it runs down the sides. Also cover your car well (both inside and out) as anywhere the fiberglass dries, it stays...forever. mine looked like this when i was done.
Prep your first brush by trimming it like the following picture. We're not going to be brushing the resin on so much as we're going to be "poking" it on and pushing it into the corners etc. Then get your matt ready by tearing it into approx 6" by 6" or so pieces. Tear it, don't cut it. It works MUCH better that way. Trust me.
Now liberally spray Pam onto the area you're gonna glass as it acts like a release agent making life much easier when the time comes to remove the hardened glass. Then hit the area with spray adhesive. Which will assist you in the next step which is covering the entire area in one layer of your torn fiberglass matt. The spray adhesive helps it stick vertically once it gets wet and starts picking up weight. When you've done all of that it should look like this;
Now get your gloves on and mix up your first batch of resin. Easy does it. Less is better. I usually cut the bottom out of a couple of plastic 2-liter soda bottles and mix up maybe two inches of resin at a time. It also helps to be as exact as possible when adding the hardener as with too little it can take forever to set (if at all), and with too much you'll find your resin hardening while still in the mixing container. If it starts to gel and harden before you can reasonably apply it you'll find yourself wasting money and your time should you find yourself having to start over. Once it's mixed start brushing/dabbing/poking the resin onto the matt, covering it entirely like this...
As soon as that's done add another layer of matt and then once again, cover it completely with resin like this...
Now it's time kick back for a minute and let it do its thing. It shouldn't take more than an hour. Two at the max. Of course the warmer and sunnier it is the less time it'll take you. Once it's hard go ahead and yank it on out. It might take a bit of muscle but don't be afraid of breaking it. Once this stuff sets it's one tough muvva. So now you should have something like the following pic only not quite as neat because mines been trimmed up and cleaned with my Dremel and a cutoff wheel which is what you want to do next. Oh and the pic's showing mine from the bottom.
Now make a frame for your amp out of your scrap wood. I took my amps width and length measurements and added an eighth of an inch to each so it would give it a nice trimmed look when I was done. It also helps if you have a router and are familiar with its use. Rounded top edges are a nice touch. Since you're even bothering to attempt this I'll assume you have basic woodworking skills so I'll skip the building of the frame. Mine looked like this...
If you'd prefer to use this info for building a custom sub box instead here's where it get's a bit different. First of all instead of two layers of matt like we've been doing, you'll want to use about six. The reason for that is that a 10" or 12" sub can really move some air. Your box needs to be strong and as flex/resonance free as possible to work properly. Also, instead of framing your amp, you'll need to cut out some rings to support your subwoofer. Now, for an amp rack just center your frame on the inside of the fiberglass "back"we made and use hot glue to hold it in place. For a sub box, use dowels to hold the ring far enough away from the fg "back" to allow enough room so the back of the sub has clearance if you know what I mean. Whichever way you're going, once that's done stretch a t-shirt (the more polyester in it the better) tightly across the front using spray adhesive on the back to hold it in place. If we're still on the same page it should now look like this;
Now get you're gloves back on, get some more matt ready and mix up another batch of resin. I should maybe point out that after each phase of applying resin your gloves, brush, and mixing container go into the trash and are replaced. Don't even think about it re-using 'em. It just ain't gonna happen. Believe me. So once you're ready, go ahead and apply a nice layer of resin to the top and sides, add a layer of matt to it, another layer of resin, another layer of matt and one last time, coat the entire thing in resin. It should now look like this...
and after it dries? Like this...
Now take your Dremel with it's cutoff wheel and cut your top opening trimming as perfectly along the wood frame as you can. Then cut an opening in the bottom large enough to fit your amp in there (If you're making a sub box, skip that last step for obvious reasons). The reason we're doing it this way will be obvious later. The idea is to hide all the wiring leaving it nice and neat looking from the front. So now we've basically got this...
Now it's "fun with Bondo" time. Mix up a good batch and spread it on thick enough to cover all the imperfections etc. Once it's dry, shave off the excess and determine whether you need more. Mine took three layers of Bondo before I was satisfied. Here's what it looked like when I was done.
And here's what it looked like after wet sanding it with 400 grit wet/dry paper. Keep it wet and be sure to get out every single divot no matter how small or you WILL see them after painting. It may be necessary to add small bits of Bondo to some to fill them back up level with the rest of the top. I usually just use my finger for that. It's easier that way. Here it is after sanding;
Now on to painting. For some of you this next tip will seem obvious, to others it'll make a world of difference however so here it is; There is a technique to getting a nice finish out of a rattle can and I'm gonna clue youin on it. Shake well, hold it approximately a foot away and....here it is...ALWAYS push the button before the paint contacts the item you're painting and don't release it until AFTER it has passed beyond it completely. In between is a nice steady stroke of moderate spped. So it's push button, move left to right, release button, push button, head back from right to left, release button, push button, back from left to right, release. Overlapping each strokes edge over the previous and always pushing the button before moving the can towards the item and releasing it only after the spray has cleared the other side. Once you get this down you will be amazed at the glossy, drip-free finishes you will produce. I only learned this two years ago and it was like a major revelation. I had never considered spray painting a learned skill before. Boy was I wrong. Here's my frame after the first coat.
And here it is after three coats installed in my trunk...
It's the exact same technique I used to make this sub box on the opposite side of the trunk;
And one last shot; A close up....
I truly hope that this might help some of you thereby justifying the time and effort involved in capturing each step and typing it out. Believe me taking pics isn't easy when your hands are covered in the stickiest substance known to man and this is easily the most I've typed in one sitting in years. I think my finger muscles actually hurt. And considering I haven't written this long of a letter to my mom since moving out of the family home over twenty years ago, if she were ever to stumble across this, I'd be a dead man.
Enjoy, and if you have any questions I'll do my best to answer them in a timely fashion.
