Return to tutorial index
Intro
You will probably have to loosen the 4 bolts holding the throttle body and move throttle body to replace the TPS. see Throttle body removal You shouldnt have to remove any of the lines going to throttle body. Two carry coolant. Seal throttle body after you are finished which may be hard with lines attached. Adjust the tps after replacing. seeTPS-adjusting/testing
Modified by vancouverbc at 8:32 PM 12/24/2009
