redtop91 wrote:Yay!!!!!!! I've been waiting for something like this. Since I have no tool to determine pitch, does this look about the right pitch for the stock sensor thingy?
Secondly I've heard that the brass adapter's have a tendency to break off. True or no?
Nice work man
The pic is kinda blurry, but once you pull the stock one out you can visually compare the two then carefully and slowly start threading your adapter into the stock location. As long as it's close, it should work since the Teflon tape will seal it up. If you can get one that is the same though, that would be best. My adapter has been fine, the sensor doesn't weigh that much. Brass, though, like aluminum, is softer and weaker than iron or steel, so it's possible, but I doubt you'd have to worry about it, unless your sensor is esp. heavy. Thanks and glad I could help you out Ryon.
pr240sx wrote:why not run a small hose, to remotely install the gauge sensor.
You could, but this stuff is what came with my gauge, so until I have issues with it, or when I get the big stuff done and have money to spend on the little stuff, I'll leave it as is.
eazye2000 wrote:That's what I did. I ran a copper line to another distribution block, and ran both the stock idiot light, and the oil pressure sending unit off that. The speed/response time is a little sluggish and doesn't update as fast... But I don't have to worry about all that weight hanging off one brass fitting.. I'll get some pics for you guys shortly.
Good work though. I love pictures.
Thanks man. Yeah, post up your set-up too for those who want a DIY remote set-up. Again though, the sensor (at least mine) isn't really that heavy, so unless you're jumping railroad tracks or something, I don't think it will cause problems.
slipstream_pnoy wrote:Sorry for the noob question but, thats a electronic gauge right? i been wanting to install a oil pressure gauge on my 240 but really have no clue wat to do. i bought a gauge and notice there isnt any wires only a small hose. im guessing its a mechcanical gauge. which is better? again for the newbie question just curious. oh and thanks for the write-up this going to be really helpful soon.
Yes, it's an electronic gauge. I edited my first line in the thread to state that now. You have a mech. gauge. Old school guys like the mech. gauges bc they feel they are more accurate. I think with today's technology, if you buy a quality electronic gauge it will work fine. Plus, if, and when, that hose fails and ruptures, you get oil in the cabin and lose pressure too. You're welcome too. I didn't think this write-up would be that helpful, glad it is to some.
