How-to: Install an Oil Pressure Sensor
homeslicej2
Car: 1990 Nissan 240SX S13 SR'd hatch
PorkChopExpress wrote:http://prosportgauges.com/remo....aspx
i believe this was requested.
Awesome thanks a lot, but it does work for the SR too and not just Subies?
s14tan wrote:I think the wheel chocks are in the wrong spot.
Come on guys, give me more credit than that . I have four wheel chocks on the car at this point, one in front of, and one behind each rear wheel. I always do that, even when changing the oil. I chock both wheels, opposite of whatever side of the car I'm working on, in front of and behind the tire. So when I change the oil and jack up the front of the car, I have both rear wheels chocked, on both sides of the tire. I'm paranoid about jacks, jackstands, wheel chocks, etc. Always have been.
s14tan
Car: 95 ZenKi SE w/ S14 SR GT28r and bolt ons
homeslicej2 wrote:Come on guys, give me more credit than that . I have four wheel chocks on the car at this point, one in front of, and one behind each rear wheel. I always do that, even when changing the oil. I chock both wheels, opposite of whatever side of the car I'm working on, in front of and behind the tire. So when I change the oil and jack up the front of the car, I have both rear wheels chocked, on both sides of the tire. I'm paranoid about jacks, jackstands, wheel chocks, etc. Always have been.
Just had to make sure you knew that.
wynnEZ wrote:Lol "Why the heck is the car moving!"
That made me LOL.
gmendoz7
Car: 240sx
does anyone know where that oil switch wire goes to the ecu or what cuz on mine it is disconnected but dont know what wire it is and cant seem to find anything on the internet on where that wire goes or what wire it is.
i put the autometer gauge on just fine on my s14 sr20det but still want the stock light off on my car please if you know tell me im frustrated already
Driftnoob
Car: S13 240sx
nice thanks !!
idahotuner
Car: 2012 Dodge Ram 2500 6.7 Cummins
93 Nissan Sileighty
93 Honda Civic hatch
2011 Polaris Ranger
o nthe sensor end of my wires for the gages i just madea loop of the wire and tightend thenuts down on it.
tripleJs15
Car: Nissan Titan
Where do you buy that brass adapter ?
positron1
Car: Project: 1993 Nissan 240SX Coupe SR
Daily: 2010 Honda Civic Coupe
Yes yes, I've been looking for this write-up...excellent! Now all I have to do is get a gauge.
homeslicej2
tripleJs15 wrote:Where do you buy that brass adapter ?
Pretty sure it came with the gauge. Summit Racing can help you out though.
positronone wrote:Yes yes, I've been looking for this write-up...excellent! Now all I have to do is get a gauge.
Glad I could help you out Posi
positron1
homeslicej2 wrote:Pretty sure it came with the gauge.
That's what I was wondering too. I thought I was going to have to hunt this part down but if it's included with the gauge then I'm set! +1 for providing this information!
homeslicej2
Welcome. I can't remember though, so if not Summit Racing has a ton of adapters and should be able to find one for you.
VNG704
sorry to bring up an old thread but would this work on the SR20DET ? Would be nice because I plan on installing an oil pressure gauge soon and always hated the spot where Nissan put the oil filter. http://cgi.ebay.com/ebaymotors...le:us With all the lines, would that effect the accuracy or the gauge's readings?
homeslicej2
homeslicej2 wrote:This install was done on a Redtop SR20...
, yeah it will work on an SR20DET. That kit won't affect the gauge's accuracy. Just make sure that the sensor will fit the adapter first.
dtowndrifter
Car: s-14 kouki
This a NPT threaded hose too...National pipe thread will not work on the block...Nissan is BSPT British Standard Pipe Thread..All auometer stuff is NPT..You could just strip the NPT threads in your block with some teflon tape though....
I want to run a hose of the oil sender hole too..Somewhere near my firewall.
dtowndrifter
Car: s-14 kouki
eazye2000 wrote:
That's what I did. I ran a copper line to another distribution block, and ran both the stock idiot light, and the oil pressure sending unit off that. The speed/response time is a little sluggish and doesn't update as fast... But I don't have to worry about all that weight hanging off one brass fitting.. I'll get some pics for you guys shortly.
Good work though. I love pictures.
I'm wanting to do this too...where did you locate the parts for this setup?
almost heaven
Car: 1985 RX7
Does the oil sending unit care what position it is in? Up, down, 90 deg sideways, something else?
positron1
My oil sending unit is screwed into a relocation kit at a 90 degree angle and I have no problems.
TroubleBound
Car: 1992 240SX Hatch
homeslicej2 wrote:Welcome. I can't remember though, so if not Summit Racing has a ton of adapters and should be able to find one for you.
They do have a BUNCH of adaptors at summit, i definitely appreciate the headsup on that as my sender didn't come with one. But im digging up this old thread wondering whether anyone knows the thread size of the stock sensor? I don't know which adaptor to order cause theres a million different sizes and they all sound weird.
TroubleBound
Okay after searching high and low for hours, i didn't find s***!Summit doesn't have them! So don't waster 2 hours on their site trying!!Anyways i tried google and turbo parts and all sorts of stuff. Nothing
Then i posted my dislike of the situation on my facebook status, and one of my OG 240 friends was like "We used to run NISsport adapters on ours, don't know if they're still around" So bam i go to their website and what would you know? Chillin right on the 240sx page. Oil Pressure gause sending unit adapter. With 1/8 bpst on the male and female end, and three 1/8 npt ports that you can use for gauge, or turbo lines, etc. Also comes with 2 plugs in case you don't use all the holes. And its not brass or aluminum, stainless steel motherf***ers! PERFECT!!
NISSport - Oil Pressure Gauge Sendint Unit Adapter
mick
Car: 1990 240SX
Glowshift.com I got one there that fits between the block and the oil filter........like a sandwich
homeslicej2
Nice find! I need to post newer pics, I've had that wiring mess cleaned up since this install.
TimTurboZ
Car: 95 S14 w/RBXX... 65' Mustang GT
I found this very useful for the info throughout the thread. THX
tjb285
Car: Nissan Maxima 1991
Missan Maxima 1996
Thank You for posting information on changing the Oil Pressure Sensor. My mothers car has been losing oil and I did not know how to fix it. Thanks Again...
homeslicej2
oh wow, no problem guys :)
scsi
Car: 99 miata
just wanted to say thanks for posting this. its 2016 and still useful lol
