What causes flooding running with very bad timing, leaking injectors, bad maf or trying and failing to start car, etc.
What to do if car floods- remove the egi pump relay and disconnect the four electrical connectors at the 4 injectors. Then start car. Disconnecting the fuel pump relay(egi pump relay) is not good enough because there is already fuel in the lines. If you are really flooded, you will have to remove sparkplugs and allow gas to evaporate which may take along time.
You'll need adjustable pliers to pull out relays or strong fingers.
Caution pistons cannot compress a liquid so can be damaged if there is too much gas in liquid form. also, the gas removes the oil on cylinders walls. it might be adviseable to pour a teaspoon of oil into each cylinder.
Modified by vancouverbc at 2:33 AM 8/10/2008
Modified by vancouverbc at 2:42 AM 8/10/2008
Modified by vancouverbc at 1:34 PM 11/13/2009
