The problem with that is that he took the caliper bracket off along with the caliper. should only take the caliper off.
Look at the first pic from the post above. There is a 14mm bolt there. Remove it (easier when caliper is still on the bracket) and you can remove the ebrake cable.melvingoku wrote:thank u so much. just not sure how to remove the ebrake tho
I did this 5 yrs ago but I dont think there is any bolt to remove. Make sure parking brake lever is released inside car. Just remove the 2 14mm pin bolt and the caliper is free. You just twist the cable with plier or something and it detaches. Its not hard if you look at how it works for a minute.jessetang wrote:
yea im sure this is the correct way bc im dont see any "bolt" on the new brake calipers i have. a coworker of mine wit exsperience in this said that there is something that needs to be adjusted. it seems to me like its just like a throttle body cable but it seems there is a tad bit more to it then that.....and u can beat exsperience lolvancouverbc wrote:
