New Wheel FAQ
Exar-Kun
Car: 2005 350Z
The new Wheel FAQ! Yay!
The Tire Rack Home Page
The Tire Rack Tech Center
Tire Rack Accessories Guide
Tire Rack Wheel Guide
Other On-Line Wheel sites:
Discount Tire Direct
10 10 Tires
Upgrade Motoring
Other links & stuff:
Basic wheel offset calculator
Detailed wheel and tire fitment calculator What does offset mean?*stock offset is 40mm on S13/S14*
Wheel weights Provides a great collection of wheel weights by diameter, but does not tell you weights by width(so it may be off on certain wheels because of width differences)...still a good 'rule of thumb' type guide to what wheels are worth buying for weight saving purposes.
More wheel weights and specs Like the site above, provide lots of useful wheel information, weights, bolt patters, finishes, etc.
Information on Wheel types/construction and pros and cons of each. Great practical info for what type of wheels you should buy, and why. Thanks to GRM. Plus sizing information, performance, etc. Track times, plus-sizing concept and feedback on what it does and why, again thanks to GRM.
Wheel Information stock specificationsBOLT PATTERNS (Torque spec).4-lug: 4x114.3 (72-87 ft/lb)5-lug: 5x114.3 (72-87 ft/lb)THREAD SIZE: 12mmx1.25
1991 S13 7 Spoke Alloy Wheels (SE Model ones)15x6 with a 40mm offset
1996 S14 5 Spoke Alloy Wheels (SE Model ones)16x6.5 with a 40mm offset
1992 Z32 Twisty Alloy Wheels (Non Turbo) (1991)16x7.5 with a 45mm offset
1992 Z32 Twisty Alloy Wheels (Turbo) (1991)16x7.5 with a 45mm offset - Front16x8.5 with a 35mm offset - Rear
Z33 Six spoke 'Track' Wheels18x8 with a 30mm offset - Front18x8.5 with a 33mm offset - Rear
Z33 NISMO LM GT4 wheels18x8.5 with a 25mm offset - Front18x9.5 with a 25mm offset - Rear
Wheel Specs from other cars that may fit a Nissan Courtesy of(the man!) SmithSR
Other Nissan Car Specs
Vehicle model('M' = Medium Offset)... model years.. wheel sizes..bolt pattern.. hub bore
NX2000/ Pulsar/ Sentra........'88-00... 13/14".. 4-100 59.20mmSentra/ Pulsar FWD..............'83-87....13" ........4-4.5... 66.06200sx(M)...............................'77-85....13/14"...4-4.5... 66.06200sx FWD...........................'94-01....13/14"....4-100...59.20240sx/200sx FWD.................'85-97.....15"....... 4-4.5....66.06240sx/200sx .......................'88-98.....15/16"... 5-45.....66.06B210/510/610/710RWD(M). '68-83.....13"........ 4-4.5....66.06240z/260z/280z/ZX RWD(M).'70-85....14/15"... 4-4.5....66.06280zx/300zx(M)....................'86-89.....15/16"....5-4.5...66.06300zx Turbo(M)....................'90-96.....16"..........5-4.5...66.06300ZX non Turbo(M)..............'90-96.....16"........5-.45...66.06310 FWD/ F10/ Stanza.........'79-89.....13/14"....4-4.5....66.06350z(M)................................'03-.........17/18"....5-4.5....66.06810/Maxima(M)....................'79-84......14"........ 4-4.5....66.061600/1800 RWD(M)..............'66-70.....14".........4-4.5....66.06Altima................................'91-01.....14/15"...... 4-4.5....66.06Altima.................................'03- .........15/16".....5-4.5....66.06Maxima.............................. '85-88......14/15"......4-4.5...66.06Maxima...............................'89-03......15/16".... 5-4.5... 66.06Sentra................................'01-03......14-"..........4-4.5...66.06Stanza................................'90-..........13/14".....4-4.5....66.06
Infiniti vehicles:G20 .....................................'91-................14/15".....4-4.5... 66.06I30/I35 ................................'95-................15"..........5-4.5....66.06J30 .......................................'93-................15"..........5-4.5....66.06M30 .......................................'90-...............15"......... 4-4.5....66.06Q45........................................'90-03.........15/16/17"..5-4.5....66.06M45 .......................................'03.................18".........5-4.5....66.06G35........................................ '03................17/18"... 5-4.5... 66.06
Other Manufacturer's specs usefull for Nissan'sNo Acura(even though the bolt pattern matches on many)
No Alfa Romeo
Amc uses a 5-4.5 RWD on it's '57-87 Ambassador, AMX, Concord, Gremlin, Hornet, Javelin, Marlin, Pacer, Rambler, Rebel, and Spirit. The AMC Eagle and Spirit 4WD from '75-89 use a 15" 5-4.5
No Audi
No BMW
No Buick
No Caddy
Chevy NovaII from '62-67 uses 13/14" 4-4.5 70.30hub boreCorvair 4 lug (but not 5 lug) from '60-64 uses 13" 4-4.5 70.30 hub boreChevy Sprint from '88-89 uses 12/13" 4-4.5, 59.61hub boreOlder models not included
Other than that, no Chevrolet uses the 4 or 5-4.5 bolt pattern
Chysler:300M....'97-03....16/17"......5-4.5.....71.50hub boreConcorde/LHS/New Yorker FWD...'93-.....15/16"....5-4.5....71.50Conquest RWD...'84-85....14/15".......4-4.5.....67.06Conquest RWD...'86-94.....15/16"......5-4.5.....67.06Laser..................'89-........14/15/16"...5-4.5.....67.06Sebring(excl. convertible)....'95-....14/15/16"....5-4.5.....67.06Older models not included
No Daihatsu
Daewoo Leganza...'98-....15"........5-4.5.......56.60
Dodge:Avenger(excl. convertible)....'95-....14/15/16"....5-4.5....67.06Daytona(laser)......'89-.........14/15/16".......5-4.5.....67.06Intrepid.................'93-.........15/16".............5-4.5.....71.50Stealth FWD..........'91-..........15/16"............5-4.5......67.06Stealth R/T AWD Turbo....'91- .....17".....5-4.5.....67.06older models not included
Eagle Summit FWD....'89-91....13/14"....4-4.5......67.06Talon FWD/AWD........'90-......14/15/16"....5-4.5....67.06TSIFWD/Vision...........'93-......15/16".........5-4.5.....67.06
No Ferrari
No Fiat
Ford:Crown Vic/LTD RWD.....'90-03...15/16"....5-4.5......70.50Crown Vic.....'03.........16"..........5-4.5....................70.50Mustang........'92-03......15-18"...5-4.5...................70.50Probe............'88-92......14-16".....5-4.5..................59.61Probe............'93-01......14-16".....5-4.5..................67.06older models not included
Geo metro from '88-01 used 4-4.5 but with 59.61 hub bore
No Honda(although bolt patterns do match)
Hyundai:Accent.................'95-99..........13"..........4-4.5.........67.06Elantra/Sonata....'89-..............14/15"....4-4.5.........67.06Excel/GLS/Scoupe...'86-...........13/14"....4-4.5.........67.06Tiburon.................'97-03..........14".........4-4.5.........67.06Tiburon.................'03................15"........5-4.5.........67.06
No Isuzu
No Jaguar
Kia Optima.........'01-03.......14/15"......4-4.5......67.06
Lexus uses too small a hub bore. 60.06.
Lincoln:Town Car.....'80-94..............15"......5-4.5.......70.50Town Car.....'95-03..............15/16"...5-4.5......70.50older models not included
MG: MGA/MGB.....'63-81.......15"......4-4.5......?hub bore
Mazda: many of these hub bores are too small. be advised.Mazda "6".....'03......16/17"......5-4.5.....hub bore:59.61rx-8..............'03.......18"..........5-4.5......59.61323/GLC.......'82-89...13/14".....4-4.5.....59.61626fwd.........'84-87....14/15"....4-4.5......59.61626/MX6.......'88-92.....14/15".....5-4.5....59.61MP3/Protege...'01-03...16/17".....5-4.5....59.61626/MX6fwd.....'93-.......14-16"....5-4.5.....67.06929..................'87-........15/16"....5-4.5.....67.06Millenia.............'95-........15/16"....5-4.5.....67.06 rx7 GSL/GTV......'86-92....15/16'....5-4.5.....67.06rx7 GSL/GTV Turbo...'86-92..15/16"...5-4.5....67.06rx7 turbo...........'93-........16/17".......5-4.5......67.06(Medium offset)
No Mercedes
Mercury:All models from..........'48-54.......15"..........5-4.5.......?hub boreGran Marquis.....'89-03.......15/16"............5-4.5.......70.50Marauder...........'03.............17/18"...........5-4.5.......70.50older models and models with smaller hub bore not included
No Merkur
Mitsubishi:3000GT FWD........................'91-01......15/16".......5-4.5......67.063000GT Spyder FWd/AWD...'92-01.......15/16".......5-4.5......67.063000GT VR-4 AWD...............'92-01........17/18".......5-4.5......67.06Galant/mirage/Tredia FWD...'83-92.......13/14".......4-4.5......67.06Diamante..............................'91-03.......15"............5-4.5......67.06Eclipse FWD/AWD.................'89-03....14/15/16".....5-4.5......67.06Galant..................................'92-97......14/15".........4-4.5......67.06Galant..................................'98-03.......15"..............5-4.5......67.06Lancer OZ.............................'01-03.......15".............4-4.5.......67.06Starion RWD.........................'84-86.......14/15".........4-4.5......67.06Starion RWD.........................'87-93........15/16"........5-4.5......67.06
No modern Oldsmobile....get it?
No Opel
No Peugeot
Plymouth:Laser...........'89-........14/15/16"........5-4.5........67.06Prowler.......'97-.............18"F/20"R......5-4.5........?hub boremodern listings only. Older(pre-'80) not included
No Pontiac
No Porsche
Saab:99/900........'72-86......15"........4-4.5.....?hub bore
No Saturn
Sterling:825/827/SL........'86-91......15"......4-4.5....?hub bore
Subaru SVX....'91-......16".......5-4.5......56.16
Suzuki uses 60.06 hub bore. While the models Aero and Swift use a 4-4.5 blot pattern, the hub bore is too small to fit the 66.06 Nissan hub. No fit.
Toyota:most all toyota cars use smaller hub bore than Nissan, hence the wheels no fit! Several cars such as the '75-85 Celica GT RWD use 4-4.5 bolt pattern with a 60.06 hub bore. No fit. Avalon uses 5-4.5 with the same 60.06 hub bore. Again, good bolt pattern, bad hub bore. Others:Cressida, Corolla RWD, All Supra incl. Turbo use 60.06 hub bore. Every modern Toyota uses 60.06 or even smaller 54.06 hub bore. None will fit the 66.06 Nissan hub.
No VW
No Volvo (65.07 and 67.07hub bore, but the 67.07 hub bore wheels are the wrong bolt pattern)
More to come later!-Chet
onosqv
Car: '92 240sx Vert
A wee bit more wheel & weight info I found while looking for 350z stock & aftermarket weight stuff:
http://www.350zmotoring.com/forums/show ... adid=15549
jason@performan wrote:the lighterst 18" wheels for the Z....
NISMO LMGT4's = 18lbs eachVolk TE & LE 37T = 19lbs eachVolk CE / LE 28N = 18lbs eachENKEI RPF1 = 18lbs eachENKEI NT03+M = 18lbs each
track wheels are 18.X lbs... close to 19lbs each.. but 8" and 8.5" while the nismo wheels are wider and a couple of ounces less...
SF Challenges are the lighter weight wheels from Volk... The SF Winnings add an extra 4lbs... depending on size...
18" SFC's are going to be around 19lbs my guess
skrill wrote:My SSR Comp-Hs are pretty light.
18 x 9 (f) = 18.5 lbs18 x 10.5 (r) = 19.4 lbs.
ydlee
What about for a 1999 Infiniti QX4 or Pathfinder?
Black R
Car: type R
this is great - if only the offset and width were posted for more of them.....
lee.
hannibal
Car: Red Line to Glenmont
More wheel weights. This site is updated quite frequently...http://www.wheelweights.net/
karmakaze
Car: 98 240sx SE
FYI: the grassrootsmotorsports links are dead.
shortlid
Car: 1999 Honda Accord EX 5spd M/T
the 4X108mm SAAB wheels for the 900's and 9000 have a 65mm hub center and so do the newer 9-5 and 9-3 with the 5X114mm or 5X4.5 bolt pattern.
qwikxr
Car: '90 S13c - SR20det, '02 WRX Stg2 Enginuity OS EMS
The newer 9-3/9-5 Saabs are 5x110.. I ran into that when trying to get my wife new wheels for her '00 9-5 Combi
Merkur XR4Ti is 4x108 (same as audi 4000 quattro) and is RWD, contrary to what many thinkMerkur Scorpio is 5x108, and is also RWD
Cameron
Car: a 240
whats the biggest wheel application to fit on a 240 S13? i was wanting to get the sportmax 006, i want the black/red anodized color option but dont want 17x7 and the only other size they have it in for 4 lug (that im not sure if it will fit without having a tiny tire) is 18x7.5 ... is that wheel too big for my 240 i havent got lowering springs on it so its not like ittl be in the wheel well.. please lemme know.. im in for purchasing if i can confirm the fit..
yokota180sx
Car: 1997 Stagea RS4, r34 front
19x9 19x10 with +20ish offsets fitsso does the smae on 18s
ZenkiCam wrote:whats the biggest wheel application to fit on a 240 S13? i was wanting to get the sportmax 006, i want the black/red anodized color option but dont want 17x7 and the only other size they have it in for 4 lug (that im not sure if it will fit without having a tiny tire) is 18x7.5 ... is that wheel too big for my 240 i havent got lowering springs on it so its not like ittl be in the wheel well.. please lemme know.. im in for purchasing if i can confirm the fit..
Soravia
Car: 2003 Audi A4 1.8T
Tire & Wheel Plus sizing link is dead.This is the updated linkhttp://grassrootsmotorsports.c...r.php
I've seen 18x7.5 with 235 on front and rear in S-13 hatch. Lowered about 2 inches.
Tire size calculator for various models from 1010tires.http://www.1010tires.com/TireSizeCalculator.asp
Modified by Soravia at 11:19 PM 8/6/2007
MrPresidentQ45
Car: 1999 Q45 1999 G20 1978 KZ1000 LTD
I'm thinking of running a staggered combo and am thinking of using 225/45-17 and 255/40-17's. Can anyone suggest a rim width/offset/backspace that will work, or would it be better to run the same at all 4 corners? (other than the ability to rotate). 1992 coupe, no suspension mods (YET!)
rbsileighty
Car: 92 S13 Hatch w/ RB20 & 05 Audi S4 Avant 6MT
brokeAs240sx wrote:A wee bit more wheel & weight info I found while looking for 350z stock & aftermarket weight stuff:
Best link of 350Z wheels/pics/offsets/weight...
http://www.350z-tech.com/zwiki...tions
VRoy
Car: 93 S13 Hatch
Detailed Wheel and Tire Fitment Calculator link is down. Found another good one with offset options also. http://www.wheelsmaster.com/rt_specs.jsp
