The Ultimate Sticky (Read Before Posting)
WDRacing
I consolidated all the old stickies into one thread to clean up the forum a bit. I also added a bunch of new stuff. If you're a new member, let me be the first to welcome you to the best 240SX board on the internet.
There isn't anything that can't be answered here on NICO. Keep in mind that the questions you want to ask have most likely already been discussed, and are archived in our vast resources somewhere. Before you post a question, be sure to SEARCH for answers. You will get more complete information, and members here will love you for it. The search button is blinking red on the top right of the NICO webpage.
240SX General Info
Hilarious Craigs List Ads
The 240SX / 180SX / Silvia Picture Thread
Best S13 Picture Thread
BRM Exhaust
240SX Tech Articles
S-Chassis list of build threads
****Basic 240SX Maintenance and DIY Articles**********************
Abbreviations
AIV removal (PAIR valve)
Air Regulator
Alignment
Alternator removal / install
Antenna Install
Automatic transmission-1991-1994-FSM
Battery terminal replacement
Battery FAQ
Belts-changing
Brakes-1991-1994-FSM
Brakes-Bleeder screw Brakes-replace rearpads
Brakes-replace rear rotors
Brake master cylinder replacement
Brake light Buying guide-1989-1998
Cam Alignment(1991-1998)
Catalytic converter
Cleaning Detailing
Clutch master cylinder
Clutch-replacing (no pictures)
Clutch-1991-1994-FSM
Codes: retrieving and reading(1991-1994)
Codes: retrieving & reading(1995-1998)
Codes: retieving &reading(1989-90 SOHC)
Code 34 detonation/knock sensor
Compression test methodology
Computer codes: reading
Control arm-front lower control arm replacement
Coolant system-general
Coolant change
Coolant-Temperature sensor
Crankshaft position sensor
CV boot replacement
Cylinder head removal (KA24DE)
Dash removal
Defogger-rear defroster(1989-1998)
Detonation sensor/knock sensor
Differential-aftermarket install
Differential oilchange
Distributor see Timing
Distributor timing
Dist. timing trouble-shoot
Door-hinge sags Needs work
Door latch troubleshooting(Driver's door)
Door Panel removal
Engine-Fuel_emission-1991-1994-FSM
Engine Removal 1991-98 BROKE LINK
ECU-serial numbers
ECU- Tuning
Electronic help
Exhaust manifold removal
Factory service manual 1989 best
Factory service manual-1989-1990 KA24E
Factory service manual-1991-1994
Factory service manual-1992-1994 Vert supplemental info
Factory service manual-1995
Factory service manual-1996 ODBII
Factory service manual-1998
Fender brace install
Fiberglassing
Flooding
Freeze plug (expansion)
Fuel filter replacement
Fuel injector replacement
Fuel Injector Leak test
Fuel pressure regulator Fuel Pressure specs(see fuel pressure reg. article 34/43 psi)
Fuel pump install
Fuel Pump install (s14)
Fuel pump Needs work
Fuel pump kill switch
Fuse & Relay Locations
Gear rations (rear end)
Ground kit
Ground-checking
Hatch-strut replacement
Hatch-water leak
Headlight troubleshooting
Helicoil
Idle-stalling at stop lights
Idle adjustment
IACV AAC cleaning & electrical trouble-shooting
Ignition lock/switch
Intake Manifold Mysteries Revealed
Intake manifold good article
Intake-AEM install on 1997
knock sensor/Detonation sensor
Light bulb replacement-dash
Leak down test- FUEL
Light bulb- S14 Climate control
MAF-cleaning
Master cylinder (brake) replacement
Master cylinder brake bleeder kit
Oil pump inspection
Oil pressure sensor
Oxygen sensor
PCV
Paint codesl
PCV-Location
Power steering-hose replacement
Power steering-rebuild for 1995
Power steering pump-removal/replacement
Power steering system-bleeding
Relays-theory
Radiator
Radio harness wire colours-89-98
Seat upgrade
Specifications (1991-1994)
Stalling-at stop lights
Starting -hard start when engine warm
Starting-hard start when engine cold
Starter trouble-shooting-Engine won't turn over Steering-also see power steering
Steering wheel removal
1990 steering rack replacement
Steering-rack bushing replacement
Steering-Tie rod removal
Steering-tie rod
Steering-tie rod/rack angle
Stereo Faq see radio
Stripped bolt remedy
Stud replacement
Subframe
Subrame(1995-1998)
Subframe bushings
Suspension-misc
1991-1993-240sx-front-strut-replacement-tutorial]Suspension: Front Struts
1991-1993-240sx-rear-shock-replacement-tutorial]Suspension: Rear shocks
Suspensiion-Swaybar end link, Tension control rod, Control arm bushings(all front)
Suspension: front lower control arm replacement
Suspension-Rear ball joint
Suspension-Ball joint replacement video
Suspension-tension control rod
Suspension: Rear sway bar
Temperature sensor-coolant
Thermostat
Throttle position sensor(TPS)
Tie rod removal
Timing Light guide
Timing-adjusting
Timing-Distributor
Timing Chain Rattle (1991-1998)
Timing chain rattle (SOHC)(1989-90)
Timing chain install (SOHC)
Timing chain replacement(SOHC) best
Timing Chain (DOHC) Incomplete
Tires
Tire chains
Top Dead Center
Transmission oil change
Transmission
Vacuum diagrams
Vacuum Pump Leak
Valve removal/seal replace
VIN-reading/decoding
Water pump replacement
Water pump(1995-1998)
Wheels
Wheel stud replacement
Wheel stud replacement2
Wheel stud replacement 3
Wheel bearing replacement-rear
Windshield wiper noise fix
Window-repairing amp (1989-1995)
Window-repairing power windows(1996-1998)
Window-stuck
Window-replace motor 1995-98
Wiring diagrams
****CUSTOM INSTALLS**********************
Air intake install
Air Intake install-S14-(AEM)
Air Intake-Custom S14
Brake upgrade-240sx to 300zx
Clutch install
DIY electric fan controller
Fan-electric wiring
Fan-wiring
Fan-electric wiring
Fan install-electric for s14
Fiberglassing
Header Intall
Hood pin install
LSD (limited slip differential) install
multichecker
Nitrous oxide-direct port wet kit 1990 240sx
Painting-headlight housing
Sound system intall 1995 240sx
Suspension-coilover conversion
Swap-auto to 5speed s14
Turbo-1989 240sx
Turbo 1990 240sx
Thanks for reading here first.
WD
