 1991 240sx: Stripped bleeder screw
vancouverbc
Tutorial Man
1991 240sx
langley
10-30-2003
Question: I rounded the edges of nut when using 10mm wrench. I did hit with hammer and use penetrating oil. Any ideas on how to get it off? The thread part should be ok because the other 3 were not seized.
Answer: Use vice grips. Very little brake fluid will come out when you remove. Specs: 33 mm long 3/8 head 10 mm thread. The head size doesnt matter but try to keep everything metric. Bleeder screw costs around 10 bucks. Canadian Tire sells them for $1.59 for some reason.
Question: I can never get all the air out of the system.(when using vacuum pump)
Answer: This may be because the threads on the bleeder screws let in air.
the vacuum makes it much easier to let air in. might have to resort to another method to bleed brakes.
All 4 of mine leaked through the threads even when tightly closed. I used some thread magic anti seize crayon crap to seal the threads. I also put copious amounts of grease around thread when bleeding to keep air out.
bleeder screw
Vacuum pump
Close bleeder screw and build up a vacuum again if you lose vacuum. Leave a little vacuum in the bottle at end so fluid in lines gets sucked into bottle. I was able to build up vacuum when screws were leaking so experiment with grease around thread area to see if that stops bubbles coming out in brake fluid.
Modified by vancouverbc at 10:56 PM 6/3/2007
Modified by vancouverbc at 6:52 AM 8/10/2008
Modified by vancouverbc at 6:53 AM 8/10/2008
Modified by vancouverbc at 3:19 PM 11/22/2008
1989-1998 240sx TUTORIALS
Factory service manuals 3
Factory service manuals BEST
Factory service manual2
Factory service manual 1989
Old FAQ
INSTALLS
Pictures of parts
AmoebAssassin
1991 Base fastback 5spd, black
Pittsburgh PA
11-17-2004
Get a pair of vice-grips and wrench it off all the way.
To replace it, just screw a new bleeder in!
1991 Black 240sx Fastback 5spd - Blacktop S13 SR20DET - GTiR T28 @ 10psi
vancouverbc
Tutorial Man
1991 240sx
langley
10-30-2003
 « Re: (AmoebAssassin)
Thanks. If anyone is interested these are the exact specs for bleeder screw:
http://www.napaonline.com/Mast...Valve
Modified by vancouverbc at 1:37 PM 5/17/2007
94_240sx
'Vert Encyclopedia
94_240SX
DFW TX
2-28-2005
 « Re: (vancouverbc)
Had exact same problem and used a big wrench to get it out. It's not a bad idea to get Speed Bleeders if you need new ones.
vancouverbc
Tutorial Man
1991 240sx
langley
10-30-2003
 « Re: (94_240sx)
Bleeder screw was 1.59 at canadian tire. The new one leaks around the threads like the old one so I put some thread magic anti seize crayon crap on the thread which sealed it. They leak even with bleeder screw shut tight. (this is when using vacuum pump). If you can never get the air out the system, this is probably why. No fluid came out when I replaced the bleeder screw and the brakes did not need to be bled. (though you should)
My bleeder screw was so rusted that the small hole in end for bleeding was clogged so make sure you cap the bleeder screw.
tutorial
bleeder
» Return to Nissan Tires, Wheels, Brakes and Suspension
