 New Wheel FAQ
Exar-Kun
2005 350Z
Georgia
9-27-2002
  New Wheel FAQ
The new Wheel FAQ! Yay!
The Tire Rack Home Page
The Tire Rack Tech Center
Tire Rack Accessories Guide
Tire Rack Wheel Guide
Other On-Line Wheel sites:
Discount Tire Direct
10 10 Tires
Upgrade Motoring
Other links & stuff:
Basic wheel offset calculator
Detailed wheel and tire fitment calculator
What does offset mean?
*stock offset is 40mm on S13/S14*
Wheel weights
Provides a great collection of wheel weights by diameter, but does not tell you weights by width(so it may be off on certain wheels because of width differences)...still a good 'rule of thumb' type guide to what wheels are worth buying for weight saving purposes.
More wheel weights and specs
Like the site above, provide lots of useful wheel information, weights, bolt patters, finishes, etc.
Information on Wheel types/construction and pros and cons of each. Great practical info for what type of wheels you should buy, and why. Thanks to GRM.
Plus sizing information, performance, etc. Track times, plus-sizing concept and feedback on what it does and why, again thanks to GRM.
Wheel Information
stock specifications
BOLT PATTERNS (Torque spec).
4-lug: 4x114.3 (72-87 ft/lb)
5-lug: 5x114.3 (72-87 ft/lb)
THREAD SIZE: 12mmx1.25
1991 S13 7 Spoke Alloy Wheels (SE Model ones)
15x6 with a 40mm offset
1996 S14 5 Spoke Alloy Wheels (SE Model ones)
16x6.5 with a 40mm offset
1992 Z32 Twisty Alloy Wheels (Non Turbo) (1991)
16x7.5 with a 45mm offset
1992 Z32 Twisty Alloy Wheels (Turbo) (1991)
16x7.5 with a 45mm offset - Front
16x8.5 with a 35mm offset - Rear
Z33 Six spoke 'Track' Wheels
18x8 with a 30mm offset - Front
18x8.5 with a 33mm offset - Rear
Z33 NISMO LM GT4 wheels
18x8.5 with a 25mm offset - Front
18x9.5 with a 25mm offset - Rear
Wheel Specs from other cars that may fit a Nissan
Courtesy of(the man!) SmithSR
Other Nissan Car Specs
Vehicle model('M' = Medium Offset)... model years.. wheel sizes..bolt pattern.. hub bore
NX2000/ Pulsar/ Sentra........'88-00... 13/14".. 4-100 59.20mm
Sentra/ Pulsar FWD..............'83-87....13" ........4-4.5... 66.06
200sx(M)...............................'77-85....13/14"...4-4.5... 66.06
200sx FWD...........................'94-01....13/14"....4-100...59.20
240sx/200sx FWD.................'85-97.....15"....... 4-4.5....66.06
240sx/200sx .......................'88-98.....15/16"... 5-45.....66.06
B210/510/610/710RWD(M). '68-83.....13"........ 4-4.5....66.06
240z/260z/280z/ZX RWD(M).'70-85....14/15"... 4-4.5....66.06
280zx/300zx(M)....................'86-89.....15/16"....5-4.5...66.06
300zx Turbo(M)....................'90-96.....16"..........5-4.5...66.06
300ZX non Turbo(M)..............'90-96.....16"........5-.45...66.06
310 FWD/ F10/ Stanza.........'79-89.....13/14"....4-4.5....66.06
350z(M)................................'03-.........17/18"....5-4.5....66.06
810/Maxima(M)....................'79-84......14"........ 4-4.5....66.06
1600/1800 RWD(M)..............'66-70.....14".........4-4.5....66.06
Altima................................'91-01.....14/15"...... 4-4.5....66.06
Altima.................................'03- .........15/16".....5-4.5....66.06
Maxima.............................. '85-88......14/15"......4-4.5...66.06
Maxima...............................'89-03......15/16".... 5-4.5... 66.06
Sentra................................'01-03......14-"..........4-4.5...66.06
Stanza................................'90-..........13/14".....4-4.5....66.06
Infiniti vehicles:
G20 .....................................'91-................14/15".....4-4.5... 66.06
I30/I35 ................................'95-................15"..........5-4.5....66.06
J30 .......................................'93-................15"..........5-4.5....66.06
M30 .......................................'90-...............15"......... 4-4.5....66.06
Q45........................................'90-03.........15/16/17"..5-4.5....66.06
M45 .......................................'03.................18".........5-4.5....66.06
G35........................................ '03................17/18"... 5-4.5... 66.06
Other Manufacturer's specs usefull for Nissan's
No Acura(even though the bolt pattern matches on many)
No Alfa Romeo
Amc uses a 5-4.5 RWD on it's '57-87 Ambassador, AMX, Concord, Gremlin, Hornet, Javelin, Marlin, Pacer, Rambler, Rebel, and Spirit. The AMC Eagle and Spirit 4WD from '75-89 use a 15" 5-4.5
No Audi
No BMW
No Buick
No Caddy
Chevy NovaII from '62-67 uses 13/14" 4-4.5 70.30hub bore
Corvair 4 lug (but not 5 lug) from '60-64 uses 13" 4-4.5 70.30 hub bore
Chevy Sprint from '88-89 uses 12/13" 4-4.5, 59.61hub bore
Older models not included
Other than that, no Chevrolet uses the 4 or 5-4.5 bolt pattern
Chysler:
300M....'97-03....16/17"......5-4.5.....71.50hub bore
Concorde/LHS/New Yorker FWD...'93-.....15/16"....5-4.5....71.50
Conquest RWD...'84-85....14/15".......4-4.5.....67.06
Conquest RWD...'86-94.....15/16"......5-4.5.....67.06
Laser..................'89-........14/15/16"...5-4.5.....67.06
Sebring(excl. convertible)....'95-....14/15/16"....5-4.5.....67.06
No Daihatsu
Daewoo Leganza...'98-....15"........5-4.5.......56.60
Dodge:
Avenger(excl. convertible)....'95-....14/15/16"....5-4.5....67.06
Daytona(laser)......'89-.........14/15/16".......5-4.5.....67.06
Intrepid.................'93-.........15/16".............5-4.5.....71.50
Stealth FWD..........'91-..........15/16"............5-4.5......67.06
Stealth R/T AWD Turbo....'91- .....17".....5-4.5.....67.06
older models not included
Eagle Summit FWD....'89-91....13/14"....4-4.5......67.06
Talon FWD/AWD........'90-......14/15/16"....5-4.5....67.06
TSIFWD/Vision...........'93-......15/16".........5-4.5.....67.06
No Ferrari
No Fiat
Ford:
Crown Vic/LTD RWD.....'90-03...15/16"....5-4.5......70.50
Crown Vic.....'03.........16"..........5-4.5....................70.50
Mustang........'92-03......15-18"...5-4.5...................70.50
Probe............'88-92......14-16".....5-4.5..................59.61
Probe............'93-01......14-16".....5-4.5..................67.06
Geo metro from '88-01 used 4-4.5 but with 59.61 hub bore
No Honda(although bolt patterns do match)
Hyundai:
Accent.................'95-99..........13"..........4-4.5.........67.06
Elantra/Sonata....'89-..............14/15"....4-4.5.........67.06
Excel/GLS/Scoupe...'86-...........13/14"....4-4.5.........67.06
Tiburon.................'97-03..........14".........4-4.5.........67.06
Tiburon.................'03................15"........5-4.5.........67.06
No Isuzu
No Jaguar
Kia Optima.........'01-03.......14/15"......4-4.5......67.06
Lexus uses too small a hub bore. 60.06.
Lincoln:
Town Car.....'80-94..............15"......5-4.5.......70.50
Town Car.....'95-03..............15/16"...5-4.5......70.50
MG: MGA/MGB.....'63-81.......15"......4-4.5......?hub bore
Mazda: many of these hub bores are too small. be advised.
Mazda "6".....'03......16/17"......5-4.5.....hub bore:59.61
rx-8..............'03.......18"..........5-4.5......59.61
323/GLC.......'82-89...13/14".....4-4.5.....59.61
626fwd.........'84-87....14/15"....4-4.5......59.61
626/MX6.......'88-92.....14/15".....5-4.5....59.61
MP3/Protege...'01-03...16/17".....5-4.5....59.61
626/MX6fwd.....'93-.......14-16"....5-4.5.....67.06
929..................'87-........15/16"....5-4.5.....67.06
Millenia.............'95-........15/16"....5-4.5.....67.06
rx7 GSL/GTV......'86-92....15/16'....5-4.5.....67.06
rx7 GSL/GTV Turbo...'86-92..15/16"...5-4.5....67.06
rx7 turbo...........'93-........16/17".......5-4.5......67.06(Medium offset)
No Mercedes
Mercury:
All models from..........'48-54.......15"..........5-4.5.......?hub bore
Gran Marquis.....'89-03.......15/16"............5-4.5.......70.50
Marauder...........'03.............17/18"...........5-4.5.......70.50
older models and models with smaller hub bore not included
No Merkur
Mitsubishi:
3000GT FWD........................'91-01......15/16".......5-4.5......67.06
3000GT Spyder FWd/AWD...'92-01.......15/16".......5-4.5......67.06
3000GT VR-4 AWD...............'92-01........17/18".......5-4.5......67.06
Galant/mirage/Tredia FWD...'83-92.......13/14".......4-4.5......67.06
Diamante..............................'91-03.......15"............5-4.5......67.06
Eclipse FWD/AWD.................'89-03....14/15/16".....5-4.5......67.06
Galant..................................'92-97......14/15".........4-4.5......67.06
Galant..................................'98-03.......15"..............5-4.5......67.06
Lancer OZ.............................'01-03.......15".............4-4.5.......67.06
Starion RWD.........................'84-86.......14/15".........4-4.5......67.06
Starion RWD.........................'87-93........15/16"........5-4.5......67.06
No modern Oldsmobile....get it?
No Opel
No Peugeot
Plymouth:
Laser...........'89-........14/15/16"........5-4.5........67.06
Prowler.......'97-.............18"F/20"R......5-4.5........?hub bore
modern listings only. Older(pre-'80) not included
No Pontiac
No Porsche
Saab:
99/900........'72-86......15"........4-4.5.....?hub bore
No Saturn
Sterling:
825/827/SL........'86-91......15"......4-4.5....?hub bore
Subaru SVX....'91-......16".......5-4.5......56.16
Suzuki uses 60.06 hub bore. While the models Aero and Swift use a 4-4.5 blot pattern, the hub bore is too small to fit the 66.06 Nissan hub. No fit.
Toyota:
most all toyota cars use smaller hub bore than Nissan, hence the wheels no fit! Several cars such as the '75-85 Celica GT RWD use 4-4.5 bolt pattern with a 60.06 hub bore. No fit. Avalon uses 5-4.5 with the same 60.06 hub bore. Again, good bolt pattern, bad hub bore. Others:
Cressida, Corolla RWD, All Supra incl. Turbo use 60.06 hub bore. Every modern Toyota uses 60.06 or even smaller 54.06 hub bore. None will fit the 66.06 Nissan hub.
No VW
No Volvo (65.07 and 67.07hub bore, but the 67.07 hub bore wheels are the wrong bolt pattern)
More to come later!
-Chet
You can live in a car, you can't drive the house.
"The essence of stupidity is doing the same thing and expecting different outcomes"
-Albert Einstein
"It is possible to store the mind with a million facts and still be entirely uneducated." Alec Bourne
2005 Daytona Blue 350Z 6 speed. NISMO Exhaust, NISMO Differential and PS cooler, JWT intake, B&M, Redline 10W30/MT90, Tomei 2 way LSD, DC headers, Comp Clutch flywheel and stage 2 setup, SPL Front upper arms, SPL rear toe link, TEIN Flex coilovers, Stoptech 355 F 328 R BBK, ARC rad panel, ARC catch can, Carbing STB, HKS DLII, ADVAN Super Racing V.2 18x9 F 18x10 R with ADVAN SPORT 255/40YR18 F 275/40YR18 R
onosqv
Q to the V
'92 240sx Vert
bewbews.com OC, CA
8-7-2002
 « Re: New Wheel FAQ (Exar-Kun)
A wee bit more wheel & weight info I found while looking for 350z stock & aftermarket weight stuff:
http://www.350zmotoring.com/forums/showthread.php?s=&threadid=15549
Quote, originally posted by jason@performan »
the lighterst 18" wheels for the Z....
NISMO LMGT4's = 18lbs each
Volk TE & LE 37T = 19lbs each
Volk CE / LE 28N = 18lbs each
ENKEI RPF1 = 18lbs each
ENKEI NT03+M = 18lbs each
track wheels are 18.X lbs... close to 19lbs each.. but 8" and 8.5" while the nismo wheels are wider and a couple of ounces less...
SF Challenges are the lighter weight wheels from Volk... The SF Winnings add an extra 4lbs... depending on size...
18" SFC's are going to be around 19lbs my guess
Quote, originally posted by skrill »
My SSR Comp-Hs are pretty light.
18 x 9 (f) = 18.5 lbs
18 x 10.5 (r) = 19.4 lbs.
bew bews!
ydlee
San Diego Ca
9-1-2005
What about for a 1999 Infiniti QX4 or Pathfinder?
Black R
type R
ATL
9-30-2003
this is great - if only the offset and width were posted for more of them.....
lee.
New Baltimore MI
8-29-2005
Enjoy.
http://www.mysportscar.com/fea...t.htm
hannibal
Online
1990 Integra, 260k miles
Atlanta GA
9-11-2002
 « Re: (lee.)
More wheel weights. This site is updated quite frequently...
http://www.wheelweights.net/
karmakaze
98 240sx SE
Knoxville TN
4-23-2005
FYI: the grassrootsmotorsports links are dead.
I am moving to Chicago! Help me find a place to live there!
Looking to buy the following:
An ECU chip burner
shortlid
1999 Honda Accord EX sedan, 5-speed manual
Derry NH
5-21-2006
 « Re:SAAB hub center
the 4X108mm SAAB wheels for the 900's and 9000 have a 65mm hub center and so do the newer 9-5 and 9-3 with the 5X114mm or 5X4.5 bolt pattern.
Want to help my brother keep his '97 J30t in the Kansas City area going till 200k.
qwikxr
'90 S13c - SR20det, '02 WRX Stg2 Enginuity OS EMS
Winchester VA
12-9-2006
 « Re: Re:SAAB hub center (shortlid)
The newer 9-3/9-5 Saabs are 5x110.. I ran into that when trying to get my wife new wheels for her '00 9-5 Combi
Merkur XR4Ti is 4x108 (same as audi 4000 quattro) and is RWD, contrary to what many think
Merkur Scorpio is 5x108, and is also RWD
~Rick
2002 Impreza WRX - Stg2 Cobb, 4" downpipe, 3" TurboXS TBE, Borla header, TD04H @ 14psi
http://www.aspergers.org ||| http://www.athletesagainstautism.com
Cameron
Online
a 240
Atlanta GA
6-3-2007
 « Re: Re:SAAB hub center (qwikxr)
whats the biggest wheel application to fit on a 240 S13? i was wanting to get the sportmax 006, i want the black/red anodized color option but dont want 17x7 and the only other size they have it in for 4 lug (that im not sure if it will fit without having a tiny tire) is 18x7.5 ... is that wheel too big for my 240 i havent got lowering springs on it so its not like ittl be in the wheel well.. please lemme know.. im in for purchasing if i can confirm the fit..
Can't stop, Wont stop, ride to the rhythm, cause I, I get down an I, I get down
yokota180sx
"Fun Sponge"
1996 Y33 cedric/1997 Stagea
Akiruno shi tokyo
11-19-2006
 « Re: Re:SAAB hub center (ZenkiCam)
19x9 19x10 with +20ish offsets fits
so does the smae on 18s
Quote, originally posted by ZenkiCam »
Need Wheels, or JDM parts?
Call me 8435646003, please take into account time change differences.
check out my BLOG! Japan goodness http://www.wagonofdoom.wordpress.com
Soravia
1991 240SX Coupe 1992 240SX SE Coupe 2003 SE-R Spec V
Jacksonville FL
11-18-2005
Tire & Wheel Plus sizing link is dead.
This is the updated link
http://grassrootsmotorsports.c...r.php
I've seen 18x7.5 with 235 on front and rear in S-13 hatch. Lowered about 2 inches.
Tire size calculator for various models from 1010tires.
http://www.1010tires.com/TireSizeCalculator.asp
Modified by Soravia at 11:19 PM 8/6/2007
1991 240SX Coupe all stock - Wrecked.
1991 240SX Coupe VQ30DE project - Sold.
1991 240SX Coupe Celica front seats - Sold.
2003 SE-R Spec V - Sold.
2004 RX8 Sport - Sold.
Next pick - IS300 or G35
MrPresidentQ45
1999 Q45 1999 G20 1978 KZ1000 LTD
Citrus Heights California
11-21-2007
 « Re: (Soravia)
I'm thinking of running a staggered combo and am thinking of using 225/45-17 and 255/40-17's. Can anyone suggest a rim width/offset/backspace that will work, or would it be better to run the same at all 4 corners? (other than the ability to rotate). 1992 coupe, no suspension mods (YET!)
rbsileighty
92 S13 Hatch w/ RB20 & 05 Audi S4 Avant 6MT
MI
2-9-2003
 « Re: New Wheel FAQ (brokeAs240sx)
Quote, originally posted by brokeAs240sx »
Best link of 350Z wheels/pics/offsets/weight...
http://www.350z-tech.com/zwiki...tions
The Project
The Old Wheels - SOLD
The Cage
VRoy
93 S13 Hatch
Oxford NC
4-14-2009
Detailed Wheel and Tire Fitment Calculator link is down. Found another good one with offset options also. http://www.wheelsmaster.com/rt_specs.jsp
*1993 S13 Hatch* The KA build has begun!
» Return to Nissan Tires, Wheels, Brakes and Suspension
