vancouverbchttps://forums.nicoclub.com/memberlist.php?mode=viewprofile&u=113&sid=10af4333bd6d2537d176e624041246eb1991 240sx: car overheating after new water pump/thermostatWed Jan 16, 2008 5:15 pm
Postby
vancouverbc »
https://forums.nicoclub.com/vancouverbc-u10923.htmlWed Jan 16, 2008 5:15 pm
Pretty sure the air is out by now. It doesnt overheat while idling but after driving a few kms it overheats. Turning on the heater does not affect the engine temperature.
There is no jiggle valve(bleeder valve) on the thermostat I bought. It was an expensive one though.
Modified by vancouverbc at 9:45 PM 1/17/2008
Postby
NM50 »
https://forums.nicoclub.com/nm50-u70539.htmlWed Jan 16, 2008 6:27 pm
Use the factory thermostat.It's a two stage unit.Without the secondary port in the back coolant just recircultes in the timing cover and doesn't flow through the radiator.
Postby
vancouverbc »
https://forums.nicoclub.com/vancouverbc-u10923.htmlThu Jan 17, 2008 7:44 pm
i put the two oem stats I have in boiling water but I only see one port even as it cools. I'm thinking the lack of the jiggle valve is the problem. Or it might just be very hard to bleed when you replace a stat.
Postby
s13erm »
https://forums.nicoclub.com/s13erm-u79868.htmlMon Jan 28, 2008 5:05 pm
how did you bleed the system? What I usually do is jack up the front of the car as high as possible, leave the radiator cap open and let it idle, constantly topping of with coolant/ or water. Keep the heater on blast once its hot make sure it stays hot, after about 20 min you shoud be good to go. Hope this helps
