If so you should hear it coming from the front... Could it be the prop shaft ? Some people here will know better than me.
It's had the prop shaft sorted under the warranty. It sounds like a rough declutch and from what I heard it happens on most of them. It only happens at low revs when you smash the throttle
Hello mate! Good to hear from someone in the UK. Thanks for your input. I'm getting used to the car not being as smooth as I would like, I believe that's a price to pay when you use a traditional transmission and not a cvt. What colour is yours? Mine is white and apparently there are only 8 of white m35h in the UK.suby81 wrote: ↑Sun Oct 31, 2021 6:39 amI have a m35h which I got at 79000 miles a couple of years ago and am also in the UK. Now on circa 120000 so I can offer some input. Nothing has gone wrong with the hybrid side at all and coming from a gs450h which have had cell failures I don't see anyone with m35h suffer hybrid issues.
So far Ive had a clunky noise on front end which was down to worn bushes ( took ages to diagnose due to crappy garage not figuring it out) so replaced control arms (which were worn tbf)and droplinks. Parts hard to come by in the UK but most are available from nissan (sometimes via amsterdam so can take couple of days) but they seem to put a bigger markup compared to online/US sites.
All really wear and tear due to how heavy they are. Gear changes can be ponderous as you know.
Tyres are a rip off but I get bigger profile ones for more comfort and they can be cheaper anyway. Warped brake rotors replaced and pads again wear and tear.
Engine wise no issues, even converted mine to LPG which no one seems to have done in the UK. Economy is good for me (real 30mpg on petrol and 25 on LPG) and similar to what the gs450h was but m35h does feel like a boat compared to it.
Mines malbec black, not sure how common they are but I've never seen any m cars on my travels. Being debadged no one even knows what marque it is anyway. Yeah, the cvt was very responsive on my lexus but the sound did grate a little.Matty1991 wrote: ↑Mon Nov 01, 2021 12:38 amHello mate! Good to hear from someone in the UK. Thanks for your input. I'm getting used to the car not being as smooth as I would like, I believe that's a price to pay when you use a traditional transmission and not a cvt. What colour is yours? Mine is white and apparently there are only 8 of white m35h in the UK.suby81 wrote: ↑Sun Oct 31, 2021 6:39 amI have a m35h which I got at 79000 miles a couple of years ago and am also in the UK. Now on circa 120000 so I can offer some input. Nothing has gone wrong with the hybrid side at all and coming from a gs450h which have had cell failures I don't see anyone with m35h suffer hybrid issues.
suby81 wrote: ↑Mon Nov 01, 2021 4:03 pmMines malbec black, not sure how common they are but I've never seen any m cars on my travels. Being debadged no one even knows what marque it is anyway. Yeah, the cvt was very responsive on my lexus but the sound did grate a little.Matty1991 wrote: ↑Mon Nov 01, 2021 12:38 am
They are like that i think naturally I'm afraid. Cant describe it myself but at light pressure you almost feel the lightest 'grab' at certain points as the wheel revolves when slowing to a stop but applying little more firm even pressure it doesn't happen ? My brakes were actually got quite bad as to the point it would grab at the slightest pressure at low speeds making me jar to a sudden stop. They were not fitted correctly apparently when I got the car so got the pads replaced and was it ok for a short while then started to get annoying again. Garage said they seem fine must be 'normal' for the car so washed their hands off it. Ended up getting ebc rotors and pads as was doing my head in and since then its made a world of difference. If you get replacements I wouldn't skimp on them as it seems its quite sensitive to the quality of brakes.Matty1991 wrote: ↑Tue Nov 02, 2021 3:00 pm
I've got a question about the brakes. This is my first hybrid. I have never had any experience with regenerative brakes. Sometimes the brakes are acting weird. They sort of pulsate when I brake lightly and sometimes. Mostly in EV mode are really sensitive, seems like they have only two positions, on or off
Thank you for your input as there isn't much info about these cars anywhere in the UK. What about the pulsing brakes? Is that just how they charge the battery?suby81 wrote: ↑Tue Nov 02, 2021 3:19 pmThey are like that i think naturally I'm afraid. Cant describe it myself but at light pressure you almost feel the lightest 'grab' at certain points as the wheel revolves when slowing to a stop but applying little more firm even pressure it doesn't happen ? My brakes were actually got quite bad as to the point it would grab at the slightest pressure at low speeds making me jar to a sudden stop. They were not fitted correctly apparently when I got the car so got the pads replaced and was it ok for a short while then started to get annoying again. Garage said they seem fine must be 'normal' for the car so washed their hands off it. Ended up getting ebc rotors and pads as was doing my head in and since then its made a world of difference. If you get replacements I wouldn't skimp on them as it seems its quite sensitive to the quality of brakes.Matty1991 wrote: ↑Tue Nov 02, 2021 3:00 pm
Think it is as if you look at the ev regen needle sometimes it doesn't always 'charge' when braking so maybe that on/off pulsing is the ev regen switching to traditional braking ?Matty1991 wrote: ↑Tue Nov 02, 2021 3:40 pmThank you for your input as there isn't much info about these cars anywhere in the UK. What about the pulsing brakes? Is that just how they charge the battery?suby81 wrote: ↑Tue Nov 02, 2021 3:19 pm
VStar650CL wrote: ↑Tue Nov 02, 2021 5:14 pmAll the Nissan/Infiniti hybrids have "cooperative braking" between the ABS, ECM and VCM in order to integrate regeneration with normal coasting and braking. Because there's a "pedal force sensor" also involved in order to tell the ECU's what you want, it isn't really a seamless process on any HEV that I'm aware of. Chances are you're just feeling subtle changes in the applied-force curves in certain speed and brake-force regions. That will always be most noticeable in light-braking because the amount of total brake force is small, making tiny changes more perceptible than they would be under heavy application. The same thing can occur in coast-down situations where the VCM may substitute regeneration for engine braking.
Hey it's me once again. Can you hear a little thump from the back when coming to a complete stop when driving on the battery? It only happens when slowing down from about 10mph to a stop. Are you expecting any issues with the hybrid system at your mileage? I'm gonna have to keep the car for at least 3 years and are expected to hit about 140k. I worry about any issues with the batteries at that mileage. Thank you
I don't hear anything like a thump at all or any noise when stopping. Maybe something not ev related in your case? I have had no hybrid issues and the battery recharges/discharges fully in my 80000 to 120000 miles of ownership if that helps.Matty1991 wrote: ↑Tue Nov 09, 2021 3:38 pmHey it's me once again. Can you hear a little thump from the back when coming to a complete stop when driving on the battery? It only happens when slowing down from about 10mph to a stop. Are you expecting any issues with the hybrid system at your mileage? I'm gonna have to keep the car for at least 3 years and are expected to hit about 140k. I worry about any issues with the batteries at that mileage. Thank you
It's not as much of a thump it's like a click when electric motors disangages. I used to have a e46 and that was a sign of a bad diff mountsuby81 wrote: ↑Wed Nov 10, 2021 1:18 pmI don't hear anything like a thump at all or any noise when stopping. Maybe something not ev related in your case? I have had no hybrid issues and the battery recharges/discharges fully in my 80000 to 120000 miles of ownership if that helps.Matty1991 wrote: ↑Tue Nov 09, 2021 3:38 pm
It is only happening when coming to a halt. Between like 5mph and 2mph. It's like a clutch disengaging noise. I don't think it's anything to worry about. It's my first hybrid you see so any noise I'm not familiar with worries me.
