troskinatior wrote:PapaSmurf2k3 wrote:No, it will leak if one of your fittings is damaged or not connected correctly... keep your eyes on the fluid level in the reservoir if you can't actually see where its leaking from. Did you bench bleed the master before putting it in?
no but i got it from a car that worked. And I was driving to school a couple hours ago and the drivers front was sticking and I couldnt go over 30, then the tiny restvor tube poped of my radiatior and I lost alot of coolant, and the temp gadge stayed at operating temp even tho it was smoking. So what kind of damage could that of caused?
What you most likely saw was steam, not smoke, and if your temp stayed normal, you didn't damage anything. You might be smelling coolant for a while though.
slikklogic wrote:Yea guess ill go with a spec stage 3 plus..and a light wieght flywheel...anybody kno why pictures never show up on majority of these diy guides? Lol
Because the majority of them were written on NICO's old software, and a bunch of the pictures didn't transfer over
Post a link to one you are having problems with, I'll see if I can get someone to fix it.
