The "I'm New Here And I have A Simple Question Thread" v2.0
PapaSmurf2k3
Site Admin
slikklogic wrote:pics-oil-pressure-and-return-bung-t140446.html
can u repair this?
I'll see if I can get it in the hands of the right people. That's definitely a good one to have.
slikklogic
Car: 99 honda civic 1.8T!
95 240sx base/se
yea i need to kno were to tap my pan with ac lol
IKGamex
Car: s13
I plan to pull my sohc this weekend and was wondering, am I going to be able remove all of the bolts by hand? (like driveshaft to transmission, engine to header, engine to transmission)
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
You can get to all the bolts you need to get to.
jlmphoto
Car: 1992 Nissan 240SX SE & 2003 Nissan Sentra SE-R SpecV
If my car is staying NA is it okay to do the emissions removal? I have to do a head gasket so I'll be deep into it anyway. Thanks in advance.
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
In florida.. yea you can do whatever you want down there.
jlmphoto
OutToWinPAHC wrote:In florida.. yea you can do whatever you want down there.
I guess I meant from the stand point of most all people I have read do it when they turbo a car. I just wanted to make sure NA did okay without it too.
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
Yeah, we have some write ups on it on 240sxtech.com too. Check that and "The Ultimate sticky"
jlmphoto
Hey thanks man. I read through them already and I'll tackle that job when we replace the head gasket. Thanks Again.
slikklogic
95 240sx base/se
what clutches are interchangable on a ka24De? ive seen people talking about rb25 and sr clutchs on it. and compition came out with some 350z converstion flywheel
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
White bunny clutch... Z32 and D21 (i think) flywheel, RB25 clutch swap (not sure what flywheel). Just try searching those, I dont know of many more.
slikklogic
95 240sx base/se
hm i see its cheaper but im not seeing a lightweight fly for the d21 or a hp capacity for them
speedeast
Car: 1990 240sx VH45 FB & 1993 300zx
Search for a flywheel by engine code instead of make and model, you'll find a lot more.
Ni$$@n240
Car: Currently 1995 S14 Se
Where are the Factory Service Manuals?
speedeast
http://www.nicoclub.com/FSM/240sx/
Assuming you're searching for 240sx.
slikklogic
95 240sx base/se
so um which motor am i looking for? because i see it has the ka or diesel or 2 diff v6's
Ni$$@n240
Yes I am. Much appreciated.
SOUNDWAVE333
Car: '90 stock s13 hatch
Hey, I'm buying a kouki. . I didn't really notice it had the vertex headlights? these
http://www.vertex-usa.com/images/access ... lightA.jpg
I always wanted these
http://i1.frsimg.com/images/detailed_im ... 1F25_4.jpg
and NOT these
http://www.maxituning.es/files/latribu_ ... 00SX_0.jpg
Can someone tell me the order of value for these? and what the names are? Thanks!
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
Ugh... the one link is FR who sells them, the price is on the page. 399.95 for OEM JDM
Vertex $690.00
last I think are the same as 2
SOUNDWAVE333
Which one?
You see how the first one is just like blocks? Well the second two have projectors, but they are placed differently. I prefer the middle ones where the projector is centered.
So what is the middle one? Japanese? Usdm? And how much for a set of them, nothing special just stock
troskinatior
Car: A Two Tone Piggy Coupe
Hey guys, im having problems starting my car in the mornings because its so cold. Ive tryed looking it up but all I got was people saying its the battery but my engine cranks the same in the cold. To get it started i have to spray tons of starter fluid in the intake and it idles fine but then if I hit the gas it starts to choke and it doesnt want to rev till it gets to operating temp. And ideas?
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
CEL present?, check codes if so
Check plug gap and timing, adjust TPS, clean IAC and TB. Look over injector O-Rings, see if you can swap MAF's
troskinatior
Ok ill start tomorrow, and also if im driving then I go into neutral my rpms lower to about 1500 and stay there for 2 seconds the drop again to idle. It isnt that big of a problem Im just curious
PapaSmurf2k3
Site Admin
2 seconds seems a bit on the long side, but a slight blip in the throttle before settling down to idle is normal.
mikes13jonz
Car: Nissan 240sx SE coupe
Hey guys on the rear side markers on the s13, i tryed changing the bulbs but didnt know how to go about replacing the old bulb out. i tryed and it flet like i was about to break it off, but i didnt want that to happen. so i was woundering if it was a twist off or pry off?
PapaSmurf2k3
Site Admin
Uhhh... not sure off the top of my head, if you post a pic I should be able to tell you. My guess is pry off, or maybe like, a push and 1/4 turn type deal.
mikes13jonz
here we go, outside pic
on the inside behind factory car jack
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
from the back counter clockwise turn
mikes13jonz
thank you sir. i appreciate the help guys.
Crazyirish
Car: Nothing noteworthy at the moment...
SOUNDWAVE333 wrote:Which one?
First link is aftermarket crappy lights.
Second pic are USDM headlights.
Third pic are European headlights.
(I think :) )
