The "I'm New Here And I have A Simple Question Thread" v2.0
PapaSmurf2k3
Site Admin
Well, it looks like you're missing some belts, radiator, turbo piping, presumably an intercooler, A/C is gone, and your brake booster is pretty rusty. You might want to change that out.
riznyce
Car: 90 240sx sr20det
got intercooler and most piping think I'm missing hot pipe and bov. Radiator belts pulleys and booster on order. I can get an ac out of another 240 right? what yr is this motor?
riznyce
trying to get this thing together. Got the car, intercooler, s15 fenders, hood and headlights. Front and rear bumpers and spoiler for 1700. Oh yeah and also apexi fc ecu and greddy turbo timer. Motor was swapped 3 years ago I saw it run the day after the swap was finished. just trying to get it running again stock.nothing crazy. Just want a fun car. 250hp or so for now. Just looking for some direction.
feoo
Car: '89 240sx Coupe
so i know that when installing a front strut tower bar, the car should be picked up to decrease stress on the towers. does this principle apply when installing a rear strut tower bar?
PapaSmurf2k3
Site Admin
Yes.
StonedRhyder
Car: 91 240sx ka24de
Just want to thank you guys for all the help! The beast is up and running again, idles a little high but I can get that. I went out one day and tried everything from scratch, TDC comp, plugs, wires, rotor, dizzy to #1 plug. Got in, Boom Bang Bam! Pressed the gas and the whole car moved, it was so load but sounded so bad a**. I mean it sounded like a V8. Then I get out and look under the car, I had forgotten to hook my exhaust headers to my cat. DANGIT! Hooked it up and it still sounds good, not like a V8 good. Holy BURP, more like a case of hick-ups that wont go away. 18 times I had to top it off, yes I raised the car and did the burp nut. Its also running just a little bit above normal temp, would that be the new cams? I have a new Thermal Temp sensor on the way, the one that is only a metal flat stick, next to the burp nut. Also noticed that some of my connections to the temp sensors are cracked/chipped. Is there a place that just sells the male/female ends of the connections? Or would it be better to get an old harness from somebody?
PapaSmurf2k3
Site Admin
Unfortunately there really isn't anyone that sells the connections/harnesses... if they make good connection and you want to protect them, just wrap them with electrical tape.
charat
Car: 1992 Nissan 240sx SE, 2008 Honda civic EX
not really new here but i have a simple questions. where do you usually get your paint from? i know ppg makes like everything but what sites do you actually order it from?
speedeast
Car: 1990 240sx VH45 FB & 1993 300zx
House of Kolor is good. DuPont makes a great line of paints. Omni is usually good for the money.
I buy all of my paint at local body supply stores...
StonedRhyder
PapaSmurf2k3 wrote:Unfortunately there really isn't anyone that sells the connections/harnesses... if they make good connection and you want to protect them, just wrap them with electrical tape.
I have some zip ties now, but the last thing I would want to see under my hood is tape..... but if thats it, its gona have to do.
PapaSmurf2k3
Site Admin
I guess I don't really know what type of damage you're talking about... but if you just want to protect them from the elements or something, I can't really think of another way to do it, other than maybe fiberglassing them to try to repair them, but that's kinda risky.
patrickm1587
Car: 1990 240sx- SR20 swap and a turbo that's absolutely too big, spools around 4,400 and I love it!!!
Quick question. My brother in law has some 195/60/15's, the backs are still good on them and the fronts will probably last another 1,000 miles. I've got a 1990 240sx, stock wheels, I'm guessing they're 15x8's? And I've got 205/60/15's on it right now, would the ones he has fit on my wheels?
PapaSmurf2k3
Site Admin
Yes.
patrickm1587
PapaSmurf2k3 wrote:Yes.
Will they look stupid?
PapaSmurf2k3
Site Admin
Nope, I ran some on my 240's stock wheels for a while. They are a little bit better in the snow due to them being skinnier.
slikklogic
Car: 99 honda civic 1.8T!
95 240sx base/se
on a 95 s14.i have a viper 2 way pager that came with the car.door locks started actn stupid on and off couple months after i got it.i noticed the door switch went from working to kinda working to not working at all.wondering if that is my problem or is it this smart entrance p.o.s. box nissan put in here?
PapaSmurf2k3
Site Admin
I would say that if you can activate your power locks using the factory Nissan switch, then its your aftermarket junk that's malfunctioning... otherwise something else is up.
slikklogic
95 240sx base/se
That's wat I thought at 1st too.I reset it n checkd all wire.still nothin but idk wats causing the switch to not work. I kno everything meets up at that box
athens240
Car: 93 240sx hatch, 86 Chevy Monte Carlo SS
On my 93 240sx hatch I did the auto to manual trans swap and it runs fine with the auto ecu but when I put a manual ecu in it from a 92 hatch the car wouldn't start. So I put the auto ecu back in and it cranked and ran like it always did. My question is why wouldn't the manual ecu work? Is it because the neutral safety switch is jumped?
PapaSmurf2k3
Site Admin
Did it crank and just not start, or did it not crank at all?
athens240
It just cranks over and over I'm thinkin the ecu itself is bad cause there's no spark and I can't hear the fuel pump running with the manual ecu.
PapaSmurf2k3
Site Admin
yup, sounds like a bad ECU.
DS562
Car: 1990 240sx
my friend has a 93 automatic dual cam and it makes a low grinding noise at exactly 1500rpm. she's done some forum searching and all anybody can say that its the heat shield, but why would it do it at exactly 1500? this occurs in both drive and neutral so im thrown off by this. it doesnt happen all the time either. the car runs and drives fine with the exception of a little trans slipping.
also, her car is bone stock and very quiet. i can hear the valves opening and closing through the valve cover, is this normal? i've never encountered a factory KA so i cant say.
thanks for the help.
PapaSmurf2k3
Site Admin
It could be a heat shield, or it could be the timing chain on the guide. How many miles are on it? Put a screwdriver to the suspect areas while holding your ear to the other end to see if you can pinpoint it better.
Also, that's probably not the valves you're hearing, but rather the injectors.
jlmphoto
Car: 1992 Nissan 240SX SE & 2003 Nissan Sentra SE-R SpecV
Will the 2003 Sentra SpecV wheels fit my 1992 240SX? I belive they are 17x7. If so, what tire aspect ratio would I need to get to fit 225 width and maintain my stock overall diameter?
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
It's been done, and it looks damn good for what it is too.
jlmphoto
I thought I saw a 240 with those wheels the other day. I might like to paint them bronze though.
DS562
Car: 1990 240sx
PapaSmurf2k3 wrote:It could be a heat shield, or it could be the timing chain on the guide. How many miles are on it? Put a screwdriver to the suspect areas while holding your ear to the other end to see if you can pinpoint it better.
thank you, i'll check back with more info upon 2nd inspection.
pella
Car: 1995 240sx S14
am curious for ka. i have a set of SR 370cc injectors. what is S14 stock fuel pump rated at? Would i be able to support these injectors with stock pump till upgrade
PapaSmurf2k3
Site Admin
As long as you aren't maxing out those injectors, your stock fuel pump should be fine until you want to start adding more fuel.
