spooled240 wrote:it wouldn't hurt, I would wrap it just to be safe.
Is there rusty water in your radiator? If you have some extra money, you should invest in an aluminum radiator. Aluminum dissipates more heat and your stock one may be clogged. The godspeed one's on ebay have good reviews and work great from what I hear.
so far it's lookin good man, I see you got the socal-style fmic (blacked out) lol
The water isn't very rusty, only slightly. I'll hop on an aluminum one once I get some extra money down the road, investing in cooling is never a bad idea.
Haha yep blacked out FMIC, you can't tell unless you shine a bright light into and stare at it for a while.
And thanks 480, I'll definitely wrap my AC lines and I'll probably wrap my turbo elbow too, that thing is really close to the AC lines. Not sure on the manifold, that thing was a ***** and a half to take off and on since the manifold kept hitting my brake lines . We shall see.
About the oil pan, I've really been contemplating between the FSM way and the "lift the engine" way. I'll think on it a little longer, but now I'm leaning more towards the FSM way.
Did you have any problems getting the motor mounts to line up when you tried to put the crossmember back on?
