For the fuel you can either get an fmu *8:1* Or get sr injectors since they're so cheap and a nismo adjustable fpr, also pretty cheap online. But of course with the sr's you'll have to get some type of tune unlike the fmu route.For as cheap as sr 370's go for you may as well. But if you want you could just knock off like 2* of tiiming or so and run an fmu on stock injectors. and run no more than like 7-8 psi.Razi wrote:I've been planning to go KA-T for a while, and I have made a list of parts I need, and I wondered if I was missing anything.
So far my list looks like this (minus the turbo)I'm only planning to run low boost. Just a little more power over stock.
-Megan Turbo manifold-Turbo elbow + downpipe-Intercooler + Piping (probably eBay)-BOV (I already got one)-Fuel Pressure Regulator, probably a Megan one (I have a question about this)-Walbro 255 Fuel Pump-Autometer gauges-Turbo timer
I already got the JGS oil lines and a T25 (I know I know, puny, but low boost for now then probably a t28 or t3 later down the road)I will possibly get a SAFC or ECU tune to dial things in so it runs nicely.Also will get some colder spark plugs and possibly new wires, but I'm not sure if I would need larger injectors for this since I don't plan to make much power.
My list seems pretty tiny, so I feel like I'm missing something.
I also had a question about the FPR.To confirm I have the correct FPR setting, I would need a A/F gauge to make sure I am running the proper setting right?
Any comments are welcome, thanks.
Thats exactly correct.Razi wrote: KA-T section is godly.
So WD, just confirming to make sure I understood everything correctly.
I just run the stock wastegate, no need for boost controller, and if I have a BOV I might stall? I was planning to recirc it.
Also, just a 8:1 FMU + stock FPR + base timing retard and no need for tune correct?
Thank you everyone that contributed!!
recirc'd = re-circled?WDRacing wrote:Should be all good if it's recirc'd
Remove and block up EGR ports, keep all OEM smog and exhaust components to swap back to stock come smog time?I've seen people Cut it, weld pennies into the bung's, and put a block off plate where the EGR used to sit.Razi wrote:Yep, I'll make sure to. What do you guys recommend that I do with the EGR tube? I must pass California SMOG crap, so I would imagine plugging up the tube would make it less likely to pass. I've seen people just block off the place where the tube comes from, I'm guessing by making their own plate to block it off?
CA has visual inspection, and unless your in good with your smog techs they might notice the AIV/EGR removed (at least they noticed mine)BUT if your in good with your smog techs the denatured alcohol trick works wonders.Razi wrote:I saw a post by WD, stating that using denatured alcohol in the gas tank would help pass inspection. So blocking off the EGR might not matter?
the O2 sensor in your exhaust manifold?Razi wrote:Also, the O2 sensor that is by the transmission is required, correct? I need to have a bung welded onto my downpipe for my car is run correctly, right?
A ka-t will not pass visual at all, unless your engine looks bone stock. As far as the EGR, I just removed the vacuum lines from the intake manifold to the diaphram that opened the EGR valve and plugged the vacuum ports from the intake manifold.Razi wrote:Yep, I'll make sure to. What do you guys recommend that I do with the EGR tube? I must pass California SMOG crap, so I would imagine plugging up the tube would make it less likely to pass. I've seen people just block off the place where the tube comes from, I'm guessing by making their own plate to block it off?
Modified by Razi at 1:31 AM 11/5/2008
