I thought only OBDII had multiple O2 sensors.. My 93 has only has one on the exhaust manifold.Razi wrote:The O2 sensors, isn't there one up on the manifold and one on the downpipe on the stock exhaust parts?
thanks man if ya need some help w/ the ka-t you can IM me at mach3gtsrRazi wrote:Hi spooled! Yeah I read through your thread twice, I like you car.I was also thinking about reverting back to stock like you did and go back to the turbo after I pass.We'll see in 2 years.
Also I found the bung part number just in case anyone needs it.Part # 14052 - 21R00
I searched a little more and found out a little more about the sensor on the downpipe, supposedly it will throw codes if it isn't plugged into the downpipe, I will weld a bung there and keep the sensor on there.
my 97 has two of them; one in the manifold and one in the downpipe before the cat. I think OBDI uses only one O2 sensor, I heard s13 OBDI ecu's only using one sensor.1unar3clipse wrote:
I can check the 97 240 next door but I was almost positive OBDII has one on the exhaust manifold and then one between the pre-cat and cat.
w/ bigger turbo it requires a retune since the spool time and flow is going to be a little different. the timing map should be changed if you are planning to upgrade from t25 to something like a gt2871r.spooled240 wrote:you won't have to tune a t-28 any differently than a t-25 IIRC. A turbocharger is merely a device to force air into an engine so different turbo's shouldn't require different tunes.
i'm just curious, if this is true then if i were to upgrade to a gt2871r i can still use my same enthalpy ecu tuned for t25? now i'm kind of lost, since i was told by scott from enthalpy that if i was going to upgrade to t2871r then i would need a reflash. scott told me the timing would be different if i was to upgrade.WDRacing wrote:You're not going to need a retune with a T28 upgrade. If you were using a TO4E or something maybe then...but the FMU has been used with a TO4E at 8 psi many times just fine.
