yeah here in socal, we just have to worry about low lifes and ****ty drivers when walking or biking lol480sx wrote:Walk or bike
Your in SOCA not like you gotta worry about the weather lol.
**Edit: Seriously, I always seem to start a new page
maybe..what the hell, I try and heal the sick too lol.Razi wrote:It's that magical Spooled touch.
no sr injectors!zerepdivad wrote:
For the fuel you can either get an fmu *8:1* Or get sr injectors since they're so cheap and a nismo adjustable fpr, also pretty cheap online. But of course with the sr's you'll have to get some type of tune unlike the fmu route.For as cheap as sr 370's go for you may as well. But if you want you could just knock off like 2* of tiiming or so and run an fmu on stock injectors. and run no more than like 7-8 psi.
You'll probably need electric fans as well most likely, and a fuel pressure gauge is always helpful, as well as a wideband, i recommend the aem uego since it fits ina regualr pillar pod. Bkr7e ngk spark plugs, z32 fuel filter, definitely going to want a better clutch if you run more than 5 psi. I was slipping on a brand new oem one on 5psi, then when i went to 9 psi i went nowhere when boost kicked in. So keep that in mind as well.
LOL you're right, it was difficult.I got it out though, I got the bung welded on it yesterday.Thanks for the offerspooled240 wrote:
dude the Oil pan was one of the hardest things to do IMO so !! LMK when you get that ish done or if you need help, I live pretty close just hit me up on aim for questions or w/e.
Ahhhh darn, my dad already bought some this morning without asking me :\.Thanks though.480sx wrote:3-5 days, usually gets out to SoCa from here fast USPS priority.
Make sure you lube the rubber gasket that seals against the block.
yeah i don't wanna mess around with my brakes, I'd rather clock the engine via custom motor mounts anyway480sx wrote:^^ No.
First I was like.spooled240 wrote:oh noez you are screwed
Then I was like.spooled240 wrote:j/k you'll be fine.
Looking good so far Razi,Razi wrote:Hopefully this week, I'll definitely have pictures once I'm done.
I got everything I needed welded today.SO EXCITED!
I can finally put on my darned oil pan and pour in some oil, and put on my BOV, and put in my water temp sensor.
