Soravia »
https://forums.nicoclub.com/soravia-u34591.html
Thu Jun 26, 2008 4:19 pm
I've decided to buy a Maxima flywheel and bolt the CPS ring to the 350Z flywheel.
Quote »On Mixing and Matching: Basically, the flywheels have a timing ring on it that is read by the Crankshaft Position Sensor, and if you use a 6-speed flywheel (which has a timing ring meant for the VQ35DE ECU) on a VQ30DE engine, it's not going to read right.
But, if you plan to use a 6-speed transmission, the 6-speed flywheel sticks out further towards the transmission than the 5-speed flywheel does. In other words, the 6-speed transmission will never engage the 5-speed flywheel because the throw-out-bearing can't reach that far.
So, you can't use a 6-speed flywheel because the CPS won't read it properly and much up timing and stuff, and you can't use a 5-speed because it can't reach the TOB. What do you do? You have two options: either weld the 5-speed timing ring to the 6-speed flywheel, or talk to Travis aka TurboS13Hatch of Maxima Forums about buying a bolt-on timing ring that has the proper timing teeth as the 5-speed flywheel, but bolts on to the 6-speed flywheel. Now, you can use the 6-speed transmission with 6-speed flywheel and still use the VQ30DE and/or it's ECU with no worries.[/quote]
