RustspecS13 »
https://forums.nicoclub.com/rustspecs13-u75597.html
Sun Jun 01, 2008 6:13 pm
Your going to run into a huge mess trying to custom fab the KA 5 speed and get it to work with the VQ, yea sure it can be done, but the KA trans are weak, high mileage usually and the time/money spent to get them to work wont be worth it.
My friend just blew up a KA trans. Granted it had 190K on it but we abused the crap out of it, and that was with a 140HP KA, with a 220+HP VQ it'll take alot less time. A z33 6 speed will last forever in a NA s13.
The VQ trans are cheap ($300-1500), better geared, MUCH stronger, bolt up if you have the RWD oil pan, and dont require many custom parts. You'll need a custom shift linkage which isnt too bad to make or buy from some where like vqswap.com and if you use a 85-01 maxima clutch you'll need a TOB spacer. Thats it.
Mazworks makes a adaptor kit to bolt up the Z32 5 speed. Its strong but not that well geared for na. Its about $1000 kit though.
And you wont have to cut up your tunnel to fit any of the three transmissions. Any will fit with no mods.
~Alex
