Soravia »
https://forums.nicoclub.com/soravia-u34591.html
Sun Jul 13, 2008 1:43 pm
You can never tell on these things, especially if you don't have about $5,000 on hand and a garage you can access anytime.
I'm expecting to sand and paint the engine bay tomorrow (already cleaned), Fab motor mounts on Tuesday and drop in the engine. The transmission will be attached only AFTER the the starter clears the flywheel and throw out bearing spacer has been fabbed.I don't have a starter on hand and don't have a way to measure the fitment to the flywheel without turning the crank. So I'm going to use the Z flywheel to get all the measurements.
I'm sure at least the engine will be in by the end of this week, the transmission will follow afterwards.After that I'll work on mounting up the starter, alternator, AC on the engine. All that should be done by next week as well. I'm going to quit my part time job on Saturday to get extra time to work on it.
By the end of the month, I expect to be taking out the dash and wiring up all the stuff. I'm not going to buy a drive shaft until after the engine starts running. $300 is not something to put into for a long time without use. The key to a successful budget swap is to buy things only when they are needed, unless you're getting a sweet deal.
