RustspecS13 »
https://forums.nicoclub.com/rustspecs13-u75597.html
Fri May 30, 2008 5:27 pm
You should research more on the VQ swap, its been done a few times before but Broaner was one of the first to do it in an S13 and Thanial (SP?) did the VQ30DE-K in the FC.
One thing that thanial did was cut the DEK intake just like you did, and JB weld it back together with the plenum half flipped so the TB was facing forward. It was much easier for him because the DEK intake is plastic, and the major source of the HP difference. The intake cams are actually smaller and the exh cams are different, but the varible intake runners are what counts. You can just get the manifold and use it on your DE and get more HP then a "true" DEK.
Broaner just cut his firewall and used a regular DE. Hes crazy and his s13 weighs in at around 2000lbs, so his way isn't for the feint of heart.
I don't think the pathy intake will fit under hood but sadly Ive never seen a VQXX in a s13 in person.
Its really nice to see another VQ swapper. Ive got a VQ35DE from a G35 to swap in, but I really need to start finding/buying the other things I need like transmission and clutch and management. Im going megasquirt though so I dont have much issues with wiring.
And I doubt you'll be able to get the 240 HUD working with the maxima ecu. Might be possible but make sure you have a working hud or you fix it and test it in a KA powered s13.
Oh and for 3.5L option, you can use the 3L timing cover and timing equiment (and cams or redrill 3.5L cams) and have a full 3.5L controlled by a 3L ecu. It will just need tuned SAFC at MINIMUM. Theres ALOT of maximas running around like that.
I might even swap on 3L timing cover because I wont be able to use VTCs (i forget what the G35 calls its cam timing system) initially but megasquirt is getting more developed and should beable to control them soon.
Hit me up on aim if you have any questions or just want to chat.
~Alex
