kerrton wrote:>SNIP<
- catalytic converter(s) - seems to be specific to my car - intense rotten egg stink entering cabin after highway trips, dealer cannot diagnose or repair
Here's some thoughts (not my own)...
"It's (the smell) hydrogen sulfide or H2S. It does not exist in the fuel or oil, which is why you can't smell it at the gas station. It does, however, come from the gasoline. Almost all gasoline contains organic sulfur compounds with sulfur levels ranging from 30 to 100 parts per million, approximately."
"As the fuel burns, the organic sulfur compounds break down into simpler compounds. If the engine is running lean (more air than is needed to burn the fuel), the sulfur is likely to be SO2, or sulfur dioxide. The catalytic converter can change this into SO3 (sulfur trioxide), which then reacts with the catalyst to form sulfates on the catalyst. Over several minutes there is a build up of sulfates. If the engine suddenly starts to run rich (not enough air to burn all the fuel), such as when you stop at a red light, climb a steep hill, or brake hard to slow down, the chemistry changes. Now the sulfates are unstable and they react to form hydrogen sulfide, which is expelled from the exhaust pipe all at once. The high concentration is the reason for the bad smell! This effect is a common problem with new vehicles because the catalyst is working at a very high efficiency. However, as the catalyst gets older, the activity drops. Fortunately for us, one of the first reactions to be affected is the formation of hydrogen sulfide. So as the catalyst gets older, the smell will go away. It should also be noted that many catalysts never smell bad. One reason might be because the vehicle doesn't run lean for much of the time, or perhaps the catalyst has an extra component that reduces the production of hydrogen sulfide."
"More than likely, you have too rich a mixture in your exhaust. When your catalytic converter is taxed by too much unburned gas flowing through your engine, the fumes coming out your exhaust pipe smell like rotten eggs. The smell itself is sulfur based but shouldn't be too much of a problem in itself. Check the inside of the tailpipe with your finger. If it's black and sooty, then you could think about having the fuel injection checked out. You may need to replace your catalytic convertor. You can go to a independent shop and have them perform a "cat efficiency test" and see what they tell you."
