Hey- I used VooDooJC's post over at fresh alloy called "fog light hack complete!"JoshTex wrote:Nice work man!! Any chance you could do a write up on how to do the fog light mod?Balance wrote:Finally got around to doing the fog light mod using the factory switch on the signal stock and installing 6000K HIDs. Match stock low beams well and being in control of my fog lights is great ]
here is the link http://www.freshalloy.com/showthread.ph ... light+hack
(not sure if that is allowed)
It was not all that complicated. Taking out the signal stalk was a snap and instead of soldering the wires off I cut them with a little left and capped them off so that, if ever necessary, I could return it to stock. After that it is just some wire running and soldering to a relay. I found a wire coming off the fuse panel that was reading 12V with the car on and 0 when it was off. I went with that so I would have control over the fogs without any other lights on but would still not have to remember to shut them down every time I parked.
This was my first time wiring up a new relay and the directions he gave pretty much explained everything. I got a relay that was already clipped into empty wires to make it all a little neat/easier. Putting in aftermarket fogs made this process easier as well although it would definitely be possible with stock fogs if you don't mind cutting up some more wires.
Good Luck!!
