martins_240sx »
https://forums.nicoclub.com/martins-240sx-u49295.html
Sat Sep 18, 2010 8:33 am
I wish i could...my computer crashed with those on it....but what i did was, Went to home depot and found a piece of pvc type tube...it was black. Note the gauge didnt fit in, way too tight. I took a file and shaved off some of the inner diameter of the pvc. I then traced the diameter of the pvc onto the bezel. With a dremel I cut it out. Then I took and positioned the pvc in the angle i wanted and secured it with jb weld stick....I used the jb weld stick to shape the entire thing. its kinda like clay but hard as a rock and doesnt crack like bondo. make sure you get the back of the bezel and pvc. then after i got it to the ruff shape i wanted i took regular jbweld, the 2 part mix, and spread it over the area like a glazing putty. I let it dry and then sanded it. Let the whole thing cure for a few days before painting it. sorry no pics
