brandonlgilbert wrote:Damn yo! for a Bawllah those are some dirty rimz homie. J/K
Nice job.
i don't understand.yokota180sx wrote:i hope you learned something today
ditto. i'm more a fan of the "euro" look anyways with the wheels tucked just slightly inside the fender.audtatious wrote:Need.......More.......Sidewall.......
Then again, I'm old and want something to take bumpz better.
Um, how does tire size affect how the suspension cambers in when compressed?yokota180sx wrote:
then as the tire moves up, it starts to camber in which wouldnt happen if it was correct size tires.
I'm not a huge fan of stretch but it is somewhat necessary and when done correctly it looks good and can be benifical.TrunkMonkey wrote:
i don't understand.
why not just use a more narrow wheel or something with a slightly hgher offset? as it stands right now, the wheel itself sticks out past the fender.
so a 9.5 wheel with a non-stretched tire with a little more negative camber wouldn't achieve the same results?
-demetrius
wider tire does NOT ="bigger" contact patch, just different shaped (so yeah, you are correct when you say you have a "better" contact patch)ddgsxr504 wrote:
Also the wider the wheel the wider the tire which means the better the contact patch and grip.... Class dismissed.
dude, im not hte person to questionyou ruck 15si rock 18 and 19sdiffernet worldglitched wrote:
you dont HAVE to stretch your tires
-dial in more negative camber-Dont slam it so much-roll/pull fenders-get wide fenders - if you MUST run such wide rims, why not get wide fenders to match-get a better fit wheel/offset for flushness, and so the rim doesnt stick out PAST the body...
what you gonna do when all that rim sticking out gets a mighty case of curb rash?
wider tires on a skinnier wheel will also help with the illusion of flushness
*edit - also take a look at my sig... Im running 225's on a 8in wide rim in the rear. If i had strait camber the fender would be sitting on the tire.
but due to the fact im running negative camber, and the fact that the suspension cambers in (more negative camber) when compressed the tire tucks in behind the fender quite nicely while under acceleration or in a corner.
there 16s dude, you are the person to question, its your "educational" thread.nope i dont understand how tire size affects suspension geometry/angles, thats why I asked....and to quote your title "VIP is ghey"yokota180sx wrote:
and not to mention, your an idiot.but iwont elaborate on why, just to piss you off, becuas eyou have no idea about how suspension geometry affects angles, and why a big *** block tire wont work for having perfect fitment
and have yuo ever heard of VIP?google it
please tell me what i said that was wrong? Maybe I will actually learn somthing from this educational thread.yokota180sx wrote:you are wrong
and ill find someone with big *** fat tires, and put the wheel on my car, and show you how it wont work....if i can find some.
apparently you cant understand the arc of a wheel as it goes up
ehhh ... I run a 17x9 up front. while 225's would be a real stretch I am running 235's which is a slight stretch which helps me clear the fender on compression of the coilover. If you do the math 235 is actually 9.25 inches. So yea even though I have a slight stretch I STILL am running a wider tire. In order for the tire to be block shaped which Yokota is referring to I would need to run 255's which is over a 10" wide tire.glitched wrote:BUT... I dont get your logic. " the wider the wheel the wider the tire" sure go ahead and run the wider tire then! oh wait, but then you dont, you stretch a skinnier tire to fit the wider wheel?
You suck at the math friend.
You probably have a lower offset which allows you to run more stretch and still look good? 235's work for me, my friend tried to get me to go 225's but then when it compresses it looks kind of sunken (with my set-up at least). One day I would like to get some better wheeld but when the set I have only cost me $350 I can't complain.yokota180sx wrote:****on a 9 i run the largest a 225-45
Im about to go down to a 215-40/225-40 setup
What i meant is think of it like thisAZhitman wrote:Good writeup, y0.
I think this is good to see... I'm still not quite comprehending how the SIZE of the tire actually affects the wheel travel, but I don't think that's what Grant meant.
That too.yokota180sx wrote:NoIf you dont have the following dont look at this thread
A turbo to turn the big *** wheelsCoiloversDiffCamber and rear toe armsaerofender roller
go awayyour going to be laughed at
