the reason for stretched tires.....pics n stuff
WidebodyZ
Car: X300 LWB Vanden Plas / W203 C240 Luxury Sedan
datsun2401972 wrote:Don't feel sorry for my s30, it's caged.
And you might listen to me because I drive a 9 second nova occasionally.
Well, that's good to hear. I <3 S30.
But what does the Nova have to do with this thread anyhow? I was making a sly remark about the sideways thing from another thread..haha, but it's okay. Never mind, it had nothing to do with 9 second cars other than the fact that it was part of the quote I borrowed. Don't see any stretched tires on drag cars.
yokota180sx
Car: 1997 Stagea RS4, r34 front
Ohhhh a 9 second nova
wowlets take an engine that naturally wants to make HP, throw a cage, some slicks, and traction barsand go 9s....real hard
Just because others need excessive grammar to retort doesn't mean I like it lol...
But seriously, I find the intricacies of a road course so much more stimulating than going in a straight line, tryin' to "keep it in the groove". Of course that in no way diminishes my love for drag racing or my respect for the professionals and hobbyists!
AmoebAssassin
Car: 1991 Base fastback 5spd, black
I guess I shouldn't send a simple reply for a simple statement.
There's no question that more goes into the gripping capacity of a car than just the size of the contact patch. I assure you I realize that.
I do know however, that increasing the width of a tire while using the appropriate sized wheel will increase the contact patch(all other factors remaining constant). If that doesn't change the coefficient of friction I must be loosing my sense of logic.
No. Increasing width does not increase the size of the contact patch, it just changes the shape of the contact patch. Contact patch area is a function of tire inflation pressure and normal load, not tire tread width.
yokota180sx
you know, i really am sstarting to liek you man lol
roplusbee
Car: 2007 350Z NISMO
Wow. This thread is informative and entertaining at the same time. Impressive.
Thank you Neel - I *thought* all of that typing I did above was in vain.
People simply can't comprehend distribution of weight, tread deformation, and contact patch shape until you SHOW them.
I taught my son about contact patch by using a wet basketball, a softball, a baseball and a rock. Think about it - it made an easily-grasped visual. He "gets" it now, and he's not even driving yet.
WidebodyZ
Hahahaha, I love your visuals..that was a great way to teach a kid.
Beancooker
Car: Current Car: 2024 Tesla Model 3
Past cars: Way too many to list
datsun2401972 wrote:Are you saying that wider tires have less progressive breakaway characteristics or that a wider tire with an appropriately sized wheel will infact decrease grip?
Short answer, YES.
If you have a car, and it is light, and you put too wide a tire on it (even with the proper wheel) there will be less PSI on the contact patch. If you have too low a PSI on the contact patch, the car will want to skid. Finding the correct amount of weight for the correct size contact patch is part of the key element.
When I refer to PSI on the contact patch, it has nothing to do with the PSI inside the tire, but the amount of weight distributed on the surface area of the road via the contact patch.
Here, let me make it simple (bean0r, you're gonna hurt yourself)....
Imagine you have a car with 185/75/15's. Park it on a piece of glass, and look at the contact patch. It will be shaped like a rectange, 185mm wide, with the longer side running parallel to the direction of the car.
Pull off the tires.
Mount some 275/40/15's (just an example, I know, there's probably no such size). NOW look at the contact patch. It's STILL shaped like a rectangle, but NOW it's 275mm wide, and the short side runs parallel to the direction of the car.
Your overall measurement, in square inches, of patch is roughly the same.
Increased the tire pressure by 10 psi - the contact patch shrinks. Drop it 10 psi, the contact patch grows.
Should we just let all the air out for a fat contact patch? Nope. We need the air to support the weight of the vehicle, since the sidewall can't do all the work.
We also need a sufficient air volume to allow for heat dissipation AND to minimize minute tire flexion from road irregularities, which builds heat.
WHENEVER you want to comprehend something like this, take it to the extreme. Imagine one wide tire across the entire rear of the car. Contact patch would be about pencil-wide, running from one side to the other. Swap that one monster roller for some skinny bicycle tires, and the contact patch becomes a straight line front-to-back.
Neither are optimal.
There's a sweet spot somewhere in between.
chitownguy
Car: 74 260z and 85 325e
4 pages already! You know just reading an engineering book which explains the most rudimentary principles really helps sometimes. (Not directed at anybody in thread who knows their ****)
datsun2401972
Car: 90 Nissan 240SX XE coupe
I as well feel my typing is in vain. When I read all of your posts it sounds like you guys are thinking about increasing tire width without an increase in wheel width. To that extent I say certainly, changing tire width without changing the wheel width will not change the contact patch any considerable amount.
What I don't understand I guess(unless I'm right), is how you can say that by taking, for example, a 5" wide wheel with a 5" wide tire and comparing it to a 10" wide wheel with a 10" wide tire, all other factors constant, that the 10"wheel/tire will not have more contact patch than a 5"wheel/tire.
Now, I'm completely dumbfounded as to how anyone could say 10" is not greater than 5". But let me apologize before hand if someone should point out the error in my statements. That would actually be appreciated.
AZhitman: Tire compound, internal construction, and suspension setup is NOTHING without width. So tell me again, how important is it?
Let me spell that out for the rest of the crowd. If a tire manufacturer has no dimension(width being part of dimension) to start with, there is no point in testing different compounds or internal construction. Why? Because the tire doesn't have dimension, without dimension there's no tire!!!
TREAD WIDTH IS IMPORTANT!
Also that was the first time I've qouted Fred Puhn, which puts your phrase,"Folks, Mama's (or Fred's) wrong again!" out of commision. But thanks for trying to reduce me, and all of Fred Puhn's readers for that matter, to a waterboy who dow kno no betta din der mama...
WidebodyZ:
WidebodyZ wrote:uhm, yah sure....so why should we listen to you again?
Is what you said, "But 9 seconds straight gets old faster than getting sideways does", is what I said. That's why I said I've driven a 9 sec drag car, so you would know that I am speaking from experience.
Yokota:I'm not bragging because I've driven a 9sec car, but it's obvious your jealous....My cousin has offered me a helmet and a driver seat to both of his drag cars because I've helped him build and crew his cars. I'd be a fool to refuse such a blast whether it's foreign or domestic.
I wasn't talking to you anyways....
WidebodyZ wrote:Don't see any stretched tires on drag cars.
I wonder if that's because increased width of the tire increases.....NEVERMIND!
Amoeb: Thank you for giving me motivation to seek out the truth instead of motivation to hate. It's because of your challenge to my knowledge that I have searched harder for information which has helped me realize how incomplete my knowledge is in general about handling effects....
If no one can clarify better than Amoeb, I'm sure I'll figure it out myself....
Before I posted this AZhitman and beancooker both provided informative replys, thank you both.
yokota180sx
datsun2401972 wrote:I as well feel my typing is in vain. When I read all of your posts it sounds like you guys are thinking about increasing tire width without an increase in wheel width. To that extent I say certainly, changing tire width without changing the wheel width will not change the contact patch any considerable amount.
But we ARE talking about the same size wheel with differnet size tires smart guy....stretching...remmeber?
AZhitman: Tire compound, internal construction, and suspension setup is NOTHING without width. So tell me again, how important is it?Well ****, i guess the integra that ate my *** in touge a few months back on liek 7js....shouldnt have, because it had small width? Your making me laugh manLet me spell that out for the rest of the crowd. If a tire manufacturer has no dimension(width being part of dimension) to start with, there is no point in testing different compounds or internal construction. Why? Because the tire doesn't have dimension, without dimension there's no tire!!!
WidebodyZ:
Hah, jealous? Yeah im jealous becuase i can go to Fuji, Mobara, Nikko, Ebisu, Motegi, Tskuba, Honjyo....shall i keep going?Whenever i want, i dont have to have someone hand me a helmet...becuase my cars are ready to go, in my driveway, ready. Not someone elses
They did the same thing i did, Just more tacktfully
I have no sympathy for people speaking out of their *** on things they don tknow.
datsun2401972 wrote:What I don't understand I guess(unless I'm right), is how you can say that by taking, for example, a 5" wide wheel with a 5" wide tire and comparing it to a 10" wide wheel with a 10" wide tire, all other factors constant, that the 10"wheel/tire will not have more contact patch than a 5"wheel/tire.
No problem - It's hard to comprehend without actually seeing it. I'm hoping I already explained it pretty well, and that you were just typing at the same time as I was, but if not, here ya go:
Weight remains constant. <-- THIS is critical.
Wheel size is assumed to be a "proper" fit, that is to say, perfectly vertical sidewalls, no stretch or bulge.
A 5" wide tire will deform front-to-back under the weight, so that the contact patch is long and narrow, in an attempt to distribute the load. A 10" wide tire will remain "rounder", as it can distribute its load ACROSS the tread. The contact patch will be very short front-to-back, however.
NOW, for lateral grip, this is fine - TO AN EXTENT. There is a point at which diminishing returns are recognized, for several reasons. Therefore, the "sweet spot" in tire sizing, every car has one, and it's different depending on the intended use and what the engineer wants to optimize.
datsun2401972 wrote:AZhitman: Tire compound, internal construction, and suspension setup is NOTHING without width. So tell me again, how important is it?
HUGELY important.
Let's drag race: You can have a 275mm wide tire, with a 460 treadwear rating. I'll bring a 205mm wide drag slick, and you'll get pounded (at least off the line).
Let's road race: You can run hard-compound, cheaply-constructed 275's (with weak sidewalls) on all 4 corners, I'll run some sticky 225's with a good stiff sidewall. You'll get pounded on the road course.
Width is important, for sure. One can't show up to a gunfight with a penknife. Load rating ALONE is usually width dependent (to the extent that internal air volume is contingent on width / height), so it's important.
But, it's not important enough that it can overshadow other, more critical factors.
I'm a tire whore. I love tires. I love learning about tires. I love the smell of them, and I love "new tire day".
WidebodyZ
Quote »so people finally understand the reason people run stretched tires (80% of the time, the performance benefit is on the side), i have decided to actually take pictures and explain it step by step."[/quote]That was what this post was about. Not all this other CRAP that has been posted. People...come on. At least ATTEMPT to stay on topic and not stray so far away from it. I hinted into that a few times...but no one caught on.
yokota180sx
speaking offNew pics in 10-14 days of a 225/40 on a 10jheh
Yeah, this kinda turned into a catchall tire tutorial.
The good news is, we're gonna make it into an article.
yokota180sx
poo, i contibuted to something usefuldamn i messed up
What a suckup.
WidebodyZ
Hahahahaha
AmoebAssassin
Alright, let's do some math (ack!). First, let me make it clear, contact patch geometries are complicated, rely on a large number of variables, and are not fully understood.
To get rid of all the crap that'll make this impossible to explain, let's just say that all contact patches are rectangular.
Now, think about the tire as a separate entity. At rest, a tire only has two forces acting on it. One of them is a normal (vertical) force, pointed downward, that is equal to whatever percent of the car's weight rests on that tire. There is another equal and opposite force that acts (pointing upwards) on the tire, and that is the reaction force that the road applies. This force is EQUAL in magnitude and opposite in direction to the force that the car applies downwards on the tire. These forces MUST be equal when the car is at rest -- if they weren't equal, they would not cancel out, and the wheel would be experiencing a vertical acceleration, which it obviously does not when it is at rest.
Now, lets say a tire is just like a balloon (which it is to an extent). Say you have a tire (not installed on a vehicle), inflated to 45psi with no load on it (since it is not on the vehicle). You want this tire to support 500lbs (one corner of a 2000lb car with 50/50 static weight distribution and 50/50 static cross weighting). So you load the tire onto the hub and put the car on the ground. The tire will deform slightly when it hits the ground, forming a flat in the circular profile of the tire when looking at it from a side view. This is the side view of the contact patch.
Because you introduce a flat in a circle, you reduce the area inside the circle. Because this circle has a depth (the width of the tire) and defines a volume, the volume inside the tire will decrease as well when the car is on the ground. Because the volume in the tire has decreased but the amount of gas inside has remained the same, the pressure inside the tire MUST increase. All this deformation is related to a number of factors (sidewall stiffness, inflation pressure, tire construction and compound, temperature, etc. etc. etc.). Once again to simplify this explanation, lets just say that a particular type of tire we're looking at will deform until the internal pressure is 50psi (up from 45psi unloaded). This property will remain nearly the same across a wide range of tire sizes.
Remember that the up and down forces on the tire must be equal in magnitude and opposite in direction. Let's say we have two tires, one is 5" wide at the tread, and the other is 10" wide at the tread. Since the tire is now at 50psi, and has 500lbs acting on it, the area of the contact patch must ALWAYS be 10 square inches in order for the forces to cancel out ( 50 lbs/in^2 * 10 in^2 = 500 lbs).
Say you have the 5" wide tire. 10 in^2 / 5 in = 2 in. This means with the first tire, the contact patch will be 2" long (front to back) and 5" wide (side to side). With the 2nd tire, 10" wide, 10 in^2 / 10 in = 1 in. This means with the wider tire, the contact patch will now be only 1" long front to back, and 10" long side to side.
Therefore, as you can see, the area remains constant despite the fact that the tread section width changes. Since frinctional force depends on contact area, we can deduce that over a variety of widths, frictional forces will remain nearly the same at constant operating conditions.
"Constant operating conditions" is the catch. Changing the width of the tire changes operating conditions, such as: the ability of the tire to absorb and shed heat / stay at operating temperature, rolling resistance, rotational inertia, cornering stiffness (slip angle vs. lateral force), and so on.
The largest thing that increased tread width changes is breakaway characteristics, because changing the tire width will change the cornering stiffness of the carcass. A narrower tire has less cornering stiffness, that is, it will produce a given amount of lateral force at a higher slip angle (a wider tire will produce the same lateral force at a lower slip angle, because it's cornering stiffness is higher). Because the narrower tire will travel through a wider range of slip angles before reaching it's "limit" (maximum lateral force), the driver has a better "feel" of when the tire will let go, as opposed to a wide tire which operates in a narrow range of slip angles before reaching it's ultimate grip and will therefore not give as much warning before breaking away.
These breakaway characteristics are very involving to quantify, and doing so would require an analysis of the vehicle's steering system (scrub radius, caster, mechanical trail), and would require quantitative knowledge of a tire's performance (self-centering torque vs. slip angle). I have done the best i can without diving into a full-depth analysis of the system.
It is possible to "over tire" a car, which is the point at which rolling resistance, rotational inertia, and the inability of the tire to stay at the compound's operating temperature, become a detriment to the car's handling.
Quote »AZhitman: Tire compound, internal construction, and suspension setup is NOTHING without width. So tell me again, how important is it?
TREAD WIDTH IS IMPORTANT![/quote]I suppose that's true, but thats a seedy argument.
The truth of the matter is that vehicle dynamics is the study of compromises in almost every context (roll centers vs. camber curves, tire size, anti-dive and anti-squat geometries). The job of the vehicle dynamicist or car setup expert is to find the best compromise; the setup which best accounts for all operating conditions the chassis is to endure.
It's the same with tires. Without proper width, the tire wouldn't operate in it's most efficient range; without compound and construction, that range of efficiency would be much lower.
^ Showoff.
Nice work, Neel.
I gotta read that a few more times, math pwns me.
yokota180sx
yeah, ill stick with my too small tires (when needed)all that other **** hurts me head
WidebodyZ
Wow...I think that warants the END OF THREAD signal.
AmoebAssassin
Hey widebodyZ...are you night garage on Ziptied?
WidebodyZ
AmoebAssassin wrote:Hey widebodyZ...are you night garage on Ziptied?
Werdizzle
AmoebAssassin
Sweet I go by the same name there as here.
datsun2401972
Thanks again Amoeb, AZhitman, beancooker. You guys just made this thread awesome.
Maybe you guys can help me out with some of your favorite book titles that will put this info on my shelf?
In this instance, I gotta say, I don't learn from books.
Spend time at a HPDE event, SCCA events, anyplace where people track their cars...
I'm one of those people who looks at something and struggles to comprehend WHY it works - it's not enough for me to be told that it works, I need to comprehend and internalize it.
I didn't have the foggiest idea how turbocharging works, so I built a boosted car. Now I have a pretty good handle on it.
AmoebAssassin
Search Amazon for "Race Car Vehicle Dynamics" by Milliken. It's an expensive book, but it's currently the bible of performance vehicle chassis engineering.
Brandon93240
Car: 1993 240sx
Yeah but when women do that you can demoralize them badly and make them do things they wouldn't normally do as payment. And for the sake of the thread tire diameter does change the arc suspension components travel, depending on the setup and amount of links involved in the suspension system it can dramatically affect arc.
