rob85 wrote:whats up everyone, i just purchased a 240 and plan on swaping in a sr20. im not to sure with how to go about doing this cause im not planing on buying engine just yet. first i want to prep the car for the engine so it can handle turns and clutch wear from drifting and what not. so iknow im going to need suspension and clucth for sure but should or can i really buy a clutch to have on my ka24 now for my sr20 later. as far as susp. goes can someone recommened some. also i got this grinding from when i try shifting into second, is that my clutch or transmission. ALL OTHER GEARS HAVE NO PROBLEM. IT tends to happen more so when in high rpm @ 1.5k rpm it just slips in otherwise it grinds. any info helps out thanks
I'm not pretending to know anything about cars, but it sounds to me like a messed up syncro and time for a transmission rebuild, from what you say.
Try double clutching it.
For my own simple question:
When I take my foot off the gas suddenly, revs dip way too low, like 200, and sometimes the engine even dies, to come back to life by making my next shift suprisingly rough(which I assume is horrible for my clutch, which I'm not exactly feeling ready to replace, I don't even own freaking jackstands or a socket set, and probably horrible for the engine too) This is usually when I throw it into neutral to coast up to a stop, or something like that, but if I spend a second before shifting for whatever reason, it can also happen.
Also, especially on a steep hill so it's more noticable, if I hit a bump like a sealed crack in the road, it feels like the car really pulls back, and then surges forward when it comes off the bump. And sometimes it feels, at lower speed, like it's doing a bit of the same surge/pull on level ground, but not really enough to be that sure of.
The engine sounds good idling, although it idles a little low, maybe 700RPM, which I think is like 50 low?
Is this spark plugs/wires/distributer? And if so, what should I get for good quality/milage/performance, considering that my car's stock and I don't need super racing overkill parts? (92 240, LE i think)
*edit* also, is it bad that my oil plug has no washer? I had a hell of a time getting it off, I had to use vice grips and a huge amount of force to get it off, I put it back on reasonably tight, but not stupid tight, with the whole thing lightly coated in oil. It's not leaking or anything. Should i go get a washer? And will autozone or somewhere be able to throw a washer at me, or will I need to order it?
