killernoodle »
https://forums.nicoclub.com/killernoodle-u129627.html
Sat May 23, 2009 4:01 pm
Do work son!
Head gaskets... followed by
Heads!
Engine in the car and the mounts I made... they are sturdy 1/4" steel plate welded to the stock motor mounts, the cross member, and the frame itself. It took me all of 25 minutes to get the motor squared up, cut out the mounts on some cardboard, then to steel, then weld them in. The mounting location is that close to the stock location. Not only that, but with FWD oil pan, everything clears! I only had to cut a small sliver off the cross member to give ample clearance to the pan. On top of this, the transmission fits perfectly in the tunnel and there is room for all the hoses, brake booster stuff, and everything else we'll need to get it running!
Look how close the TR3650 mount is to the stock trans cross member mount is. I just have to go pull one from the junkyard and cut it up and weld it back together to get this part done.
Q45 rear sub-frame! Got it from pull-a-part in an olympic record time of 30 minutes to remove (difficult without air tools... breaker bar and cheater pipe to the rescue!). Yeah, they were closing so we were in a hurry.
Notched subframe, needs to be cleaned up with the grinder.
Close up of rack clearance, note how nicely the PS lines tuck under the transmission/motor.
Plenty of room for headers.
Firewall clearance... everything looks good! Head coolant lines match up nicely with the heater core lines, another bonus!
The only issue is hood clearance. The hood would fit without the bracing structure, it barely hits the valve covers when closed. An aftermarket hood with some kind of bulge would definitely help here.
The sway bar needs re-positioning, but that's no biggie.
