xdarkrune »
https://forums.nicoclub.com/xdarkrune-u43896.html
Thu Jan 11, 2007 9:53 pm
need help with my DCC setup! i have my wires setup as so:
1. Green/White stripe, on small white 7 pin plug, this needs to be ran to an Ign+. This wire can be moved to an empty spot on large white 16 pin plug (see page 1 of ericherm1's thread for the location it is moved to)
2. Blue/Red stripe, on the small white 7 pin plug, this needs to be ran to a Ign+. I tied this wire into the large Blue/Red stripe wire on the blower motor.
3. Red, the plug with a single wire, this needs to be ran to a constant +12v. I tied it into the memory wire for the radio, Red/Black stripe.
i do not have my ground wire hooked up, as i am not sure if i should cut it and ground it on the USDM side of the harness, or on the JDM side of the harness, i am confused about that and need clarification! i am assuming i ground the side the goes to the DCC unit, and not the side that goes to the harness, correct?
anyway my problem is that since installing the DCC my interior dome light sometimes works, and sometimes doesnt, and my car alarm is the same. could this be caused becuase i do not have the ground wire hooked up?
also one last thing, i removed the motor that i belive controls the fan speed, i think the mode motor? it kind of looks like the JDM air mix motor. was i suposed to leave this in?
any help you guys can give me would be great! im about 75% done with my install and just got these last few hills to climb! thanks!
