Silvia Digital Climate control Instructions................
ob1
Car: 95 240sx S14
I have a 95 s14 and succsefully installed the dcc I could help install for a fee of course hit me up if you need help
flipRB240
Car: 1993 nissan 240sx
put all the pics back pls... i need to do my conversion
so my sunload sensor is orange and black wire.. from my jdm DCC harness is bright green/black stripes and green/yellow stripes. so which wire goes to what wire?
can someone post a pic of what these parts look like and where they can be found in the vechile i need to pull out from and where they go on the 240sx S13
1. Japanese Digital Climate Control 2. Plug to fit Japanese Digital Climate Control (from 89 Infiniti i-30) 3. Sunload sensor* (from 96 Maxima) 4. Plug for Sunload sensor* 5. Ambeint Air Temp Sensor* (from 96 Maxima) 6. Plug for Ambient Air Temp Sensor* 7. In-Vehicle Air Temp Sensor* (from 96 Maxima) 8. Plug for In-Vehicle Air Temp Sensor* 9. Aspirator* (from 89 Infiniti i-30) 10.Thermo Control Amp (from 96 Maxima) 11. Plug for Thermo Control Amp 12. Thermal Transmiter (from 89 240sx) 13. Plug for Thermal Transmiter
Modified by flipRB240 at 6:53 PM 6/30/2009
Modified by flipRB240 at 6:54 PM 6/30/2009
ka-t4u
hey guys sorry to bring this one back from the dead, i was just wondering if i would be able to pull this off with just the pigtails cut at the back of the dcc and getting all the sensors, resistors and such from other cars?? thanks!! or if not can i at least make the a/c and heater work?? with just the pigtails?
i got the time and patience and can sort out everything else, and i don't mindd making my own custom harness, as long as i can make this thing work properly, with the full auto function, preferably.
amolao
Car: 1989 Hatchback (the first one...) w/ Autech sr20de S15
Does anybody know how pin 45 monitors the ambient temp sensor while at the same time connected in some weird loop to the auto amp and pin 41.....??? This is in the JDM ECU sr20 S15, the earlier JDM sr versions seems to be wired somewhat differently.
I seen various explanations to PIN 45, from working in conjunction with the AC when detecting high temps in the engine and raising the rpms to detecting cold temps and adjusting the climate control accordingly with the other sensors.
Joseph Rivera
Car: 1992 Nissan 240SX 2Dr Coupe
I'm missing metal rod & plastic clip off the motor. Are they needed? If so where could I dind one.
amolao
Hey, greetings fellow nico members!!!
Just got done with my instal, everything works but just like another member in this thread, my AC compressor and condenser fan are staying on constantly as soon as the key is turned. I tracked it to a permanent ground being applied from the dcc unit to the ac compressor relay circuit. Seems like the unit's A/C switch is not "switching" like it should....anybody having the same problem?? Maybe a defective DCC unit?? This instal is on a 1989, just for reference purposes.
PS.I also had the temp motor problem just like Broadfield's and just like he said a quick re-soldering of the connector terminals took care of it. Thanks for the info, Broadfield..!!
ericherm1
Car: 1997 Pickup XE 2.4L 4x4 Single cab short box
1991 BNR32 Skyline GTR
1991 240sx SE SR20DET + S13 Silvia Front end swap (Sold)
Heeeeeeeerrrreees Johney!!!!!
Yup, I'm back from a long hiatus. Brief history, Sold the S13 almost 10 years ago and now just picked up a 1991 GTR so you'll see me floating around the GTR section time and again....
See you guys around!
DUDE!
Welcome back!
owca180sx
Car: NIssan 180sx
Hi guys,
I have rather strange question. Anyone know where can I get sub hernes connectors to JDM DCC unit? I got all I need except loom. Making loom in not a problem but i need to buy connectors. Maybe anyone could give me a hint what type of connectors are used or... maybe someone wants to sell connectors with or without wiring? Any response will be more than welcome.
ericherm1
Are the pictures showing up? I know photobucket is an issue but I've been re-linking in many of my other threads across multiple forums.
