Silvia Digital Climate control Instructions................
ka-lin
Car: 1989 Nissan 200sx(European version) S13 CA18DET
Last question, I promise ! About the sunload sensor:It has a black and orange wires.The other side (to the JDM DCC) has a light green/black(LG/B) and green/yellow (G/Y) wires.
Which wire of the sunload sensor where I should connect to the DCC wires:Black to ?Orange to ?
I appreciate your help, guys
Modified by ka-lin at 8:45 AM 12/17/2007
94_240sx
Car: 94_240SX
ka-lin wrote:Last question, I promise ! About the sunload sensor:It has a black and orange wires.The other side (to the JDM DCC) has a light green/black(LG/B) and green/yellow (G/Y) wires.
Here you go. This sensor has polarity, so you must connect it right.
Black --> Green/Yellow (G/Y)Orange --> Green/Black(LG/B)
Here's the pics for visual guys.
2iv0 sx
I just recently pulled out the DCC off the front clip with all sensors except for one.
I'm missing the cabin air temp sensor that's attached to the aspirator hose..
I need this part
Anyone have one for me? email me please
ka-lin
Wow, thanks for the input, fella;)
positron1
Car: Project: 1993 Nissan 240SX Coupe SR
Daily: 2010 Honda Civic Coupe
Talk to Dammitboy, he can get all those sensors for you. Digital climate control sensors FS zerothread?id=208899
94_240sx
Car: 94_240SX
positronone wrote:Talk to Dammitboy, he can get all those sensors for you. Digital climate control sensors FS zerothread?id=208899
Dammitboy wrote:This thread is old & closed. See the newer one plese.
2iv0 sx, I have one and emailed you this morning.
2iv0 sx
Here's his other listinghttp://forums.nicoclub.com/zer...age=1
Thanks 94_240sx get back at me.
94_240sx
Car: 94_240SX
I found another write up. This one uses analog air mix door cable instead of metal rod from JDM s13, so you can still do it even though you only have the motor.
http://www.ziptied.com/?p=49
Anyway, I have some pics to share. Went to junkyard and had a chance to take some good pics.
Look at the box in the middle and you will see the cable under the box. That's air mix door cable.
I found another box that's under the golve box and attached it to the center one like this.
Air mix door linkage. I moved it back and forth and door was maving this way.
This is a box that you see under the glove box. Blower resitor can be found in this one.
Side view.
This is what broadfield was talking about. It was already touching the line like this. It's a thin line, so you can carefully bend it. You can use back of screw drive and push it. No need to grind down the JDM resistor. Coorect me if I'm wrong.
I looked at it carefully, but I still couldn't find where aspirator hose goes to. Can anyone point out where it goes?
94_240sx
Car: 94_240SX
Found out where the aspirator hose goes on USDM air box. Ignore the outline and cut like this to install.
This is JDM air box.
My question is... Is it going to be possible to cut out a hole and install the hose without taking the dash out?
Modified by 94_240sx at 12:00 PM 1/14/2008
Dammitboy
Car: 92' Nissan 240
Absoblutely you can. I did mine with a dremel tool. Don't have one? Get one!
94_240sx
Car: 94_240SX
Dammitboy wrote:Absoblutely you can. I did mine with a dremel tool. Don't have one? Get one!
I sure do. I'm really good at Dremel. Good to hear that.
ka-lin
A question about the temperature readings.....Mine shows wrong values for the outside temp.For an example, when outside is near 0 degrees celcius, the DCC main unit shows -9 degrees celcius (diring the test mode).
The same thing happends with the in cabin temp readings. I can feel a temperature not more than 25 degrees, but the DCC shows about 32.
Is that normal, do I need to replace the sensors (during the test DCC reported all of they are ok), or what else can I do?
Thanks for the attention, fellas
Dammitboy
Car: 92' Nissan 240
There is a calibration procedure that you need to follow, iirc, that is accessed through the diagnostic menu.
94_240sx
Car: 94_240SX
I'll add one more picture since we don't have a clear shot. This is the door linkage.
MrFairlady
Modified by MrFairlady at 5:06 PM 3/2/2008
subzero122188
Car: 1990 240SX SE
Does anybody know if the sensors from a 94 maxima would work? like the sunload sensor, ambient temp sensor, in car temp sensor?
positron1
Yes. They say exactly which year model on the first couple pages of this thread I can't remember exactly which ones but it is the Maxima's that came with the Autocons.
RCG_Savage
Car: '92 240sx fastback
Does any have a schematic for the JDM blower motor sensor and the JDM HVAC control and USDM parts?If you have any schematics on any of those parts it would be a great help to me.
Modified by RCG_Savage at 1:57 PM 4/12/2008
Kalypso
http://cgi.ebay.com/ebaymotors...ZWDVW
its not hard to find either....
ka-lin
Sorry to bring this thread up again, but I have an issue with the outside temp sensor, as I already say in my previous post. Outside is near 28 degrees Celcius (28 C), but the sensor in TEST mode shows 11 C ! What can cause that? I tried with a outside sensor from Nissan Primera (Infinity G20) but the readings was still the same.
What can be that? Any ideas to fix?Thanks..
ka-lin
Does anyone know which is the exactly place, where originally the air mix mode motor are situated?Especially, the angle and position of the motor to the heater matrix box.
I have some troubles, when the temp. are set to 32 C, any noise coming from the motor...But it works well at the moment..
5yk0s13
Car: SR20 S13 Vert
SWEET!! Awesome Job On The Install I Want To Do The Same Thing!! What Exactly Is The Purpose Of The Sun Sensor Though??
911Silvia
Car: 1991 Nissan Silvia
can Anyone tell me if this is hard to swap into a 1991 Silvia. Probably already been asked before.
Kalypso
how do you define hard
do it, and revel in your accomplishment.
911Silvia
what I ment was I shouldnt have to go cutting my harness or anything up where I have an already JDM car. Should it just be "Plug and Play"?
Hoffman5982
Car: '95 sr20det 240sx
sorry to bring this thread back,but i didnt want to start a whole new thread just to find out this is a dumb question.i just want to know if I could put an s13 digital ac into my s14?I like the looks of the s13 better because the s14 just looks kind of cheap to me
kouki munster
Car: 97 base 240
Not easily.
turoki
Car: 92 240sx
well first of all sorry but i need to cpr this thread im confused on a few things on is how to wire up the ambient temp sensor and the other is how to wire the a three prong sensor the one that goes in the hvac box thanks again and sorry for reviving this thread again, i have to i can post pics
turoki
Car: 92 240sx
hooked everything up and a few things dont worki have the digital climate control and jdm harness
1 the mode selector for the head/defrost/feet is not working 2 the motor will not torn on at all
i have a prong sensor if that helps the 3 pin out of a 96 maximaalso i read that you need to depin or do something with the brown connector this is really confusing what do i need to do depin and rewire?
Modified by turoki at 10:47 AM 5/27/2009
Modified by turoki at 11:01 AM 5/27/2009
turoki
Car: 92 240sx
bummmmmp need help guys
