Silvia Digital Climate control Instructions................
40daws
Is everyone that has the aspirator hose using it and cutting the hole in the airbox ? Or just hooking up the cabin temp sensor onyl,no aspirator hose ?
Dammitboy
Car: 92' Nissan 240
40daws wrote:Is everyone that has the aspirator hose using it and cutting the hole in the airbox ? Or just hooking up the cabin temp sensor onyl,no aspirator hose ?
Do it the way OEM intended it to be- Cut out the small triangular shaped piece on the driver's side of the heating/cooling unit, epoxy in the aspirator plug, attatch hose to it then plug hose into the cabin air temp sensor. Attatch the cabin air temp sensor to your radio bezel surround so it can access cabin air.
Kevin
40daws
Thanks for the info Kevin ! How tough is the material of the airbox ? Exacto knife or will by kersaw knife do it ?
Dammitboy
Car: 92' Nissan 240
40daws wrote:Thanks for the info Kevin ! How tough is the material of the airbox ? Exacto knife or will by kersaw knife do it ?
You might be able to X-acto it, but i dremeled' mine. Goodluck
Kevin
240_ESEX
Car: 1993 240sx Hatchback
You think you'd be able to take a pic of where on the Air box you cut your triangle into for the Aspirator hose?
240_ESEX
Has anybody had any luck with full function?
iiymij
Car: 240sx coupe
i got to cut out a blower harness and ill probably be trying to Y splice it together once I get some pix from a friend who has the whole harness. Looking at the wire diagram I think that's what we're missing =P
240_ESEX
Well definitly let us know what goes on whether its good news or bad.
iiymij
Car: 240sx coupe
connecting the Blue Red wire from the 7 Pin to the motor harness doesnt work =P
i think ill pm a couple of the ppl who have done this for more assistance and for 240_esex when u use your DCC to change the temp I noticed mine only has about 4 temp settings, usually only change from 18 - 22 c on my dcc? is yours the same?
Modified by iiymij at 1:02 PM 2/23/2007
240_ESEX
No. Mine adjusts all the way up to 32 degrees.
iiymij
Car: 240sx coupe
fudge thats not good news... anyhow still waiting for my day off work to check out my a guys harness that has it all.
240_ESEX
Alright. Hopefully that'll help out
40daws
The ambient temp sensor (thanks Dammitboy)that mounts at the hood latch,where do those wires connect to ?
240_ESEX
Here you go. Copied it directly from Beatupsx's thread:3. Ambient Temperature Sensor - (LG/Y +) - (LG -) - Same as above. (these wires are on the small white 7 pin plug)Hope that helps.
Hey Iiymij, did you ever get a chance to check out the wiring to fix the blowing speeds?
05civse
Car: 91 s13 hatch
anyone know the resistance of the outside temp. sensor at say 50* F? then you you could just put a resistor at the DCC and not have to run wires to the front. I would just find the risistance of the sensor at your average outside temp and be done since it isn't all that importaint if you have the cabin temp sensor. so, anyone know it at 50*F?
iiymij
Car: 240sx coupe
After i tried splicing it i havent done anything yet, been busy at work and I got a chance to email Kevin to see which ignition wire it plugged the B/R to since he had the same problem and had to splice it somewhere else.
theres a black blue wire on the 7 ping, not sure but i might wanna try to splice that into the blower resistor sensor and splice the b/r there too but if i have time to and if this ****ty weather lets up. So right now waiting for kevin's reply =P
positron1
Car: Project: 1993 Nissan 240SX Coupe SR
Daily: 2010 Honda Civic Coupe
I installed my new havac motor with the shift linkage and swing arm now I'm having another problem. I used the diagnostic mode to test the motor and it cycles thru so it's good and I have it mounted in a good spot with room for the arm to move. The problem is that when I use the up/down arrows to cycle thru the hot/cold functions, the motor doesn't move...not one inch. Anyone know what could be the problem?
iiymij
Car: 240sx coupe
needs time to warm up, does that with mine as well and i dont get the full different changes with each degree i change the temp until its been on for a while
argh did u get the blower to work properly?
positron1
iiymij wrote:needs time to warm up, does that with mine as well and i dont get the full different changes with each degree i change the temp until its been on for a while
So it does move but only after it warms up? I haven't tried to get the blower to cycle thru the different speeds yet but it is working.
240_ESEX
positronone, you have it blowing at full speed only, too?
positron1
Yeah, I've been meaning to dig in and try to fix that but I've put it off. I need to figure out why this havac motor won't move in regular mode and I need to correctly mount the bi-level motor so that it doesn't lock up. How about you? What's your progress so far?
240_ESEX
My only problem is the controling the speeds. Its just at full blast. As far as I know, my Havac Motor works fine. It goes through the different temperatures and I can hear it moving behind the dash. But I blew my motor, so I've been working on the swap lately, then the new engine had a blown head gasket after a couple of days of work running it, so I've mostly been busy with that.
needforjdm
Modified by needforjdm at 9:43 PM 4/15/2008
iiymij
Car: 240sx coupe
that's swt hope you can get your full swap in, right now i'm wondering where the blue red wire from the 7 pin harness goes to, and the black and blue wire on this 7 pin wire.
if you need pix ill find time to get pix up asap
btw if you could, could you measure how long the swing arm should be for the linkage on the air mix motor?
needforjdm
iiymij,
Could you email me the photo ? btw, I need your help in getting me photos on the usdm connectors that showing all the harness. I also need the USDM bi-level connector ( brown ) showing the harness. I would like to make a comparison.
thanks
the blue/red harness from the 7pin is connecting to the blower motor plug.
Modified by needforjdm at 2:32 AM 4/9/2007
iiymij
Car: 240sx coupe
iiymij wrote:
From my harness i have part of the harness after that. You can see this B/R wire turns into a fat wire after?
Hey sorry i couldnt get pix here some from the last page
as for the brown connector where is it? ill take pix when it's not rainy here. I think i saw two brown plugs, theres one to the left inside the center console and one to the right of the glove box?
I think i tried tying the b/r wire to the blower motor plug and it didnt work for me.,
should i just try to strip some of the b/r wire from the OEM Motor plug and just add in the b/r from the 7 pin?
needforjdm
needforjdm
wiring for the blower motor plug & the speed sensor
Modified by needforjdm at 8:56 AM 4/10/2007
iiymij
Car: 240sx coupe
curtousy of "tuned by jdm"
is this what u were looking for? usdm brown connector
needforjdm
yupe. i need the usdm brown connector in its original position where the harness is not re-pinned yet!
