You need that gray rod and the linkage that fits on the end of the rod to make that motor work from what I understand. I hooked up my air/mix motor with the rod but I don't have the swing arm linkage to connect the rod to the lever that switches between the hot/cold so my system is incomplete right now. I read the instructions a hundred times and there was no mention of that other unit or the black box so I took it out but when I realized that I had no swing arm linkage I put it back. ?????????????iiymij wrote:bump* and
For number 4 the air door mix motor correct?
I've been trying to install the thing to the back but I don't have that gray rod that goes with it? Do I need it or how would I make it fit my USDM part?
for my USDM it has the same looking unit but for the white part its got this nub on a track of some sort? Am I missing something here?
At the back I've also got this black box or plug + harness and I have no idea how to remove and then move it, I don't see this part in any of your guys pictures so I was wondering is my 240sx different?
mines a 92 coupe with AC power windows and power sun roof?
Alright I misunderstood something on here then cause I thought you were able to use one off of a Maxima, and I figured the ones from a Maxima and Q45 were the same as long as they had a DCC.iiymij wrote:... the Blow Motor resistor sensor needs to be from a JDM clip in order for you to cycle through the 1 different speeds ...
actually i went through the entire thread again and you can use a JDM clip blower motor resistor or sensor from a 96 maximaericherm1 wrote:You must have the correct blower motor speed sensor. If your using the factory US blower motor sensor you will get the exact response as your getting now.
You can get the proper one from a Japanese clip, eBay, or 96 Maxima, and I heard that the digital control unit in the later model 300zx uses the same speed sensor and other sensors but not sure so if anybody wants to check it out to confirm this...please by all means.
Do you have a Nissan FSM? Becasue if its a Haynes or Chilton theres a good chance it might not show everything. Yes I can see all USDM parts on teh FAST program and most of all JDM parts to, the important ones here mainly PS13 SILVIA and RPS13 SILVIA....iiymij wrote:wow that is great info how'd you get a fsm that showed all of that cuz mine doesnt? and is that a program for all the car parts? let me know if I can get my hands on that
I'm having trouble putting together my max cold door motor (m73) , my analogue is just a white tube and a gray wire inside and for the life of me I can move the max cold relay (m71)
The reason for the hot/cold mix door motor not moving is becasue you must have the cabin temp sensor pluged in and the mix door motor must be the JDM one.positronone wrote:Got a havac motor and plugged it up. The first time I turned on the DCC the havac motor moved but it has not moved again since then. I move the temp all the way up and down but the havac motor has not motioned since the first time. Anybody solved this problem? Anybody got one of those clips that go on the end of the havac motor swing arm for sale?
Modified by positronone at 3:16 PM 12/3/2006
As far as I can tell from looking at all teh Nissan/Infiniti USDM FSM's all Nissan and Infiniti Fan Control Amp AKA Resistor AKA Blower Control Amp are all 3 wire units so it definantly looks like you must use a JDM Fan Control Amp AKA Resistor AKA Blower Control Amp.......unless someone can prove this false please do and show me a 4 wire Fan Control Amp AKA Resistor AKA Blower Control Amp from a USDM vehicle or show me how you made the 3 wire work....iiymij wrote:
im offically confused once again
so I guess it doesn't have to be jdm... i was wrong argh sorry man im still learning how to do this as well
Modified by iiymij at 12:09 AM 12/23/2006
You need this part heres a pic of how I did mine, btw this is the JDM rod, I reveresd teh yellow plastic piece basically fliped everything around that way it would mount to the shaft and then your able to secure it with teh lil phillps screw:positronone wrote:I mounted the havac motor but I think that I am missing something because there is no way to connect the swing arm to the lever that actually opens the door. Anybody got pics or milk?
