Peak hp and peak torque are not the same thing as a powerband. KA-T does not generate those torque numbers at low RPMs.Fahaka wrote:Yeah I think Greg has that torque number beat by a few lb/ft...when he was running 10 psi...
...VLSD<HLSD<CLSDmmm240 wrote:if you think you can install the helical unit, then there's no reason why you can't install the kaaz unit.you may also want to look into a viscous (VLSD), and get a new viscous couplerit's also considered a 1.5way
Ummm, not so.Edub1 wrote:I've looked at changing to a 3.69 gear. There would be no appreciable difference in 1st and 2nd would only be a tad longer but it should be one hell of a tad. 3rd on up is where the gears would really stretch out. Hell, the guys at Nissan feel it's a better fit in the S15 at what, 205HP IIRC.
If I was the type to like to experiment with stuff like that I'd be all over that swap.
Yes of course, but when you multiple the two ratios to get the final one you see a more marked increase in the higher gears. I'm talking in terms of overall MPH gain in each gear.AZhitman wrote:
Ummm, not so.
It is the same reduction across ALL gears.
Switching from a 3.54 to a 4.08 in my Q45 resulted in (I think) a 17% shorter ratio across the range.
This statement did nothing for your arguement. The s15 transmission has totally different gear ratios than s13s and s14s so no comparison can be made.Edub1 wrote: Hell, the guys at Nissan feel it's a better fit in the S15 at what, 205HP IIRC.
The gear ratios, or the transmission comparison? 6 gears compared to 5 gears will always give you a shorter gear. But no matter your transmission ratios, the diff puts it to the ground. Your diff ratio isn't called FINAL drive for nothingEdub1 wrote:
What are they?
HurryupandrunS13 wrote:The gear ratios, or the transmission comparison? 6 gears compared to 5 gears will always give you a shorter gear. But no matter your transmission ratios, the diff puts it to the ground. Your diff ratio isn't called FINAL drive for nothing
That'll work. Better make sure you have more than 2 quarts.hybrid_flyer wrote:what weight gear oil is this supposed to use?? I have a can of Nismo 80-90 sitting here.
jason
i second that!a_ahmed wrote:that article which talks about LSDs and the chase to 12sec quarter mile was really awesome, it was even very fun to read. Really good writer.
yea i dont my car with 155hp would be able to bust figure 8's or donuts or give the back end out with a hlsdAZhitman wrote:Still loving it...
Got a chance to go WAIL on it pretty good this past weekend.
Took one of the kids out to make some ruckus, wound up in an empty lot doing figure-8's until the smoke got too thick...
Unfortunately, the driveshaft didn't like all that abuse, and went buh-bye, so I installed my aluminum one from UltraRev.
