AZhitman wrote:That'll work. Better make sure you have more than 2 quarts.
Okay, I just finished the diff. It's not on my car yet, but I put them all back together and filled it with 75w-90 Mobil 1 fluid. I'll just leave it overnight to see if there's any leak and install it sometime tomorrow. Everything went smooth with no problems. I have a couple of questions.
1. I followed FSM and used about 1.5 quarts. I wonder why Greg said more than 2 quarts. BTW, filler plug is on the left side of diff over on s13 unlike below picture.
2. I turned the input shaft by hand and worked fine, but when I turn output shaft by hand, I can hear more noise than before. I tried several times and it looks like noise is coming from inside. Is this normal? I'm 100% positive that I installed ring gear, shims, brearing races, outshaft, side seals and everything correct. I hope it's noisy beacuse of different gears inside. My open diff was fairly quiet when I did the same thing to it.
