S3t0_S13 wrote:sorry dude, can u kinda walk me through it? drivetrain is not my expertise...
so u can buy only the pumpkin of the helical and have it "dropped in" the S13 stock diff?
basically have the gears pulled out, and nothing else needed? or am i missing a halfshaft or output shaft here
thanks
Basically the only way to find the s15 helical is to buy the internals--all the auctions on ebay are just the interal helical unit itself, not the entire pumpkin. That means you have to swap out the s13 guts to put the s15 stuff in.
The vast majority of the s15 units that I've seen don't have a ring gear attached, so you have to use your stock s13 ring gear with them as a result. You need an impact gun to break the bolts loose--I'd imagine it's a giant pain in the *** by hand. The ring gear is what determines your rear end ratio, and I'm pretty sure you have to swap out the pinion to run a different ring gear.
Anyhow, if you're intent on getting one, I'd probably just spend the money and have it installed and then not worry about it.
As for the Obx, it runs around $400 shipped on ebay, and from the few reviews I've read it's fine. I know that the Honda guys who use the obx units like to disassemble them and retorque everything down (since obx does a so-so job of quality control, apparently). Honestly, if I were to do it again, I would go with the s15 unit again, since it's a direct bolt on with no hassle. However, I also picked up my helical for $340 shipped (for everything) which is an unusually good deal, as far as ebay goes.
Alex
