Not true. You probably just didn't notice the gap around the bolts because it is pretty small. Regardless, to do it right with a 4.08 ring gear you should use 0.5mm wall sleeves on 4.08 bolts, or order the special nismo bolts.AZhitman wrote:OK - Take a stock OPEN S13 diff. Remove the ring gear bolts and ring gear. Attach the ring gear on the HLSD and put it in the pumpkin. Don't buy bolts.
Special bolts are JUST for those N/A guys who want to run 4.36 or 4.63 ratio ring gear.
Also note that Helical/torsen differentials NEVER lock.AZhitman wrote:This thing LOCKS and GRABS, even accelerating hard out of a turn.
Sweet. $500 bucks aint bad, sounds good.nismofly wrote:http://cgi.ebay.com/ebaymotors...wItem
theres a direct link to the one i got mine from
hes got a bunch laying around, he just lists them one at a time
So Greg, you have a HLSD Installed in a stock S13 Open Diff. Pumpkin with a R32 Finned Diff. Cover while useing Stock Ring Gear/Axel Bolts... Is this Correct? I am just looking at seeing what I need to do when I replace my Welded Diff. Let me know if there was anything incorrect or something else that I missed. Thanks.AZhitman wrote:griego is right, if you run a 4.08 (stock ring gear), you have no need for different bolts.
Keep in mind, I removed my 4.36 diff + pumpkin completely, as well as my J30 axles, and replaced them with the HLSD (into a stock S13 open diff pumpkin) and returned to stock S13 axles.
I also kept my larger-capacity, finned diff cover that came with my R32 diff, and filled with Royal Purple.
Thanks! Ahh specifics are confusing!!! But are a must!!! Now the question is... Meshies with tax returns or HLSD.... or BOTH with a little saving. Prob be best to replace the welded diff though, previous owner had it done and I do not know who actually did it... Its unsafe I tell you unsafe!! (Shh... its my excuse)AZhitman wrote:Correct.
And as for "gap", I noticed none, and we were looking for it. In fact, the bolts seemed to barely want to go through, but I suppose I see what Dean's getting at.
Methinks the "sleeve" issue is a non-issue, and a call to a local driveline assembly tech just confirmed it - not that one person's experiences are "confirmation", but here's the reasoning:
Regardless, even if there were a .5 mm "gap", the ring gear is basically a press-on fitment (much like a hubcentric wheel), so some play around the bolt holes is irrelevant. The ring gear will be perfectly centered.
Bolts were all cleaned, chased with a die, and installed with Loctite, in sequence, to the FSM specs. Make sure you do this, it's an extra measure of insurance.
no it wont! that thing has more weld in it than....idk it has a lot of weld in it!!DJButton wrote:I must get a HLSD! I'm getting ready to swap my RB in and I know that the welded diff from the previous owner is gonna crap out soon.
S3t0_S13 wrote:*puts on flame suit*wait, so i can get a S15 hsld gears and drop it into the stock S13 open diff?
To elaborate on this, you're also going to want s15 output shafts to link up to the rear axle shafts. Thats pretty much everything...94_240sx wrote:
s15 ring gear uses 13mm and s13 uses 12mm bolts. The bolt I got is 12mm with 13mm shank as you can see in the pic. There'll be a slight play if you use s13 bolts, but people just torque the bolts down, fabricate sleeves or get Nismo bolts like I did. AZHitman and other people have had no problem with original s13 bolts, so you can call it "Drop in".
Yeah you post too quick for me, you are gunna need the half shafts to be safe, rumor has it some people did without. What do you mean speedo? Speedometer, ball huggers? I don't understand how the speedometer comes into play with a differential. You should do it yourself, unless you honestly don't think you're capable...S3t0_S13 wrote:comp im on at work shows no pics, so ill check it out later,ive found just the diff for sale for dirt cheap, seller thought that its REQUIRED to have the half shafts, so i can get it for relativly cheap, great
only thing is im just wondering how much of a difference it will make with the speedo and i gotta find me a shop 2 do the gear swap
lol, I never understood why drifters would rather go with a clutch type. Seems like a helical would work just a well...e1_griego wrote:I've got s15 output shafts for sale if anyone's lookin'
I highly recommend this diff for the non-dorifto crowd, though at our last local drift event a local guy with an s15 was out drifting with his helical.
Alex
the different gear ratios effect your speed and speedometer dont they?thenillaz wrote: I don't understand how the speedometer comes into play with a differential. \
i meant dropping in the gears from the s15 diff into my S13 diff, nah ive heard some horror stories and wouldnt trust myself with it!thenillaz wrote: You should do it yourself, unless you honestly don't think you're capable...\
every other thread ive read has looked down upon the helical as a drifting lsdi have to get any seat time at the track, so i dont know, i mean it cant be worse then a open diff now can it? but then again ive never seen any 240's runnin hlsd's at D1GP or Formula D and such, i dnno dude i wanna give it a trythenillaz wrote:lol, I never understood why drifters would rather go with a clutch type. Seems like a helical would work just a well...
